Drum hubs on disc brake spindles??
![](http://www.pozziracing.com/Media/cbb_3r.jpg)
Joe:
You guessed right, I'm looking into CBB options (cheap, big brake). I knew the bearing part numbers were the same for the drum hubs and disc rotors, but didn't understand what caused the track width changes. The factory disc brake set-up pushes the track width out about 1/2" wider than drum brakes on each side. The difference must be in the disc brake rotor/hub and not in the spindles. BTW - thanks for the link.
Rodney
Rodney
Murco
Brakes/Hydraulic Systems
March 7th, 2013 11:50 AM
