Disc Brake Conversion 67 Cutlass
Old Sep 5, 2011 | 12:36 AM
oldsman7's Avatar
First off Happy Labor Day and thanks to all the Olds Guys that helped me out over my tenure of using this site! I am fixing to convert my 67 Cutlass to front discs so adios front drums! I bought this kit that came with:
2- 11" Drilled and slotted front rotors
2- New calipers loaded with semi metallic pads and hardware.
2- New spindles.
2- New caliper brackets
2- New disc brake dust shields with anodized finish
1- Complete bearing seal set.
2- Rubber brake hoses
1- 9" original looking brake booster with proper mounting hardware
1- 1" bore master cylinder
1- disc in the front drum in the rear proportioning valve.
1- new disc brake line set. (right front and left front steel brake lines are included.
Well the kit says I need to modify the rear brake line and I imagine it may have something to do with a bend or re-farrelling. I am not sure so I wanted to see if any of you guys did a job like this on your Olds and if so what modifications did it consist of and if you ran into any troubles. Any advice/experiences is welcome.
Old Sep 5, 2011 | 06:42 AM
Ranzan's Avatar
Getting There
cant help with the rear brake line issue since i replaced all mine but the kit is a easy install.
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
ricardo
Jul 27, 2010 05:26 AM
JCervantes
Dec 28, 2008 07:39 PM
tarheeldoc
Nov 5, 2008 11:52 AM
