Convert from power to manual brakes
Old Mar 10, 2024 | 08:50 AM
ajr2820's Avatar
Looking to convert from power to manual brakes. I have a few questions....
Going with a 1" bore MC....will this bolt directly on the existing studs on the firewall or is a bracket/adapter needed?
This is the MC I believe I need....
https://www.wilwood.com/MasterCylind...emno=261-13269
Will the valve on this setup replace the current metering block? (front disc, rear drum OEM type brakes)
There is the potential I will convert the rears to disc in the future. Will this MC work for that setup as well if I decide to go that route?
Old Mar 10, 2024 | 01:01 PM
Year? Model? Current brake configuration in the car?
Old Mar 10, 2024 | 01:44 PM
Loaded68W34's Avatar
When going to manual brakes, you will want the smallest bore size possible. I am currently running a 15/16" master on a 67 Camaro convertible with 13" discs all around. It stops good, but I plan to go down to a 7/8" for even better stopping. The adjustable prop valve from wilwood will replace the your original distribution block. Plan on taking it out and fine tuning it. wilwood has a well described adjustment procedure. If you are working on a 67-72 A-body, the wilwood master will fit. I had to enlarge the center firewall hole on the Camaro a little to get the rubber boot to go through.
Old Mar 10, 2024 | 01:52 PM
The factory used a 1" master on the manual disc brake W-cars. We still don't know what car or brakes the OP has. Of course, most people don't realize that Olds built a couple of cars besides the 1970-72 A-bodies.
Old Mar 12, 2024 | 07:00 AM
ajr2820's Avatar
1972 supreme. Originally had power drums all around.Current configuration is disc front/drum rear.
Old Mar 12, 2024 | 11:04 AM
Assuming the front discs are the OEM-style single piston calipers, the easiest way to do this is to simply use the 1" bore M/C used on the W-cars. I have this on my 70 W30 and it stops just fine. Pedal pressure is not unreasonable. A smaller bore in the M/C will reduce required pedal force but also requires more pedal travel to move the same amount of fluid. This can be a problem if the rear shoes are worn and the self-adjusters are not keeping up. If the rear brakes are properly adjusted, this will be fine.
Old Mar 12, 2024 | 01:50 PM
69455's Avatar
I am running Wilwood 7/8 bore,
Disc all the way around.
Not really needed however I do a double pump, one to move fluid and second for pressure.
Almost like power brakes.
Very happy.
Old Mar 13, 2024 | 04:56 AM
ajr2820's Avatar
Current setup is OEM-style. Sounds like this one will work fine. Plus it frees up some space in the engine bay. Was getting tight with the 455 with tall valve covers.....
Tiberian Fiend
Nov 6, 2018 05:24 PM
David DeCan
Brakes/Hydraulic Systems
Feb 19, 2016 09:41 AM
KDV
May 27, 2012 08:02 AM
droptopcad
Oct 13, 2010 12:16 PM
Southern_Hospitality
Mar 19, 2008 09:39 PM
