Manual Drum to Power Disc Conversion
Greetings everyone!
I'm new to the sight, and I apologize if there's already another thread I haven't found that covers this.
I'm the proud owner of a '72 Cutlass Supreme with manual drums. I'd like to convert to PB disc/drum.
I've been reading some horror stories about Power Drums to Power Discs, how horrifying is it to go from Manual to Power?
Would I be better off trying to whiz in the corner of a round room?
Thanks for any input!
Joe Padavano has posted a great thread on this.
https://classicoldsmobile.com/forums...sk-brakes.html
The only rims you would have to replace is if your SSI's are the earlier 14X6" wheels and then not every year of manufacture. For your vintage they should be 14X7's and those will work fine on the disc brakes.
Not a difficult swap, and for something you drive much I think its a nice upgrade.
John
John
Thanks John! Love this site BTW!
I'll hafta get the measuring stick out tomorrow.
If I do just go with Power Drums...
I need a booster and a master cylinder, correct? Aren't the M/C's different bores for power and manual?
Appears that m/c is 1" bore, same for Power Drum/Manual Drum.
Looks like I'll need an:
11" Booster
Booster Sleeve
PB Booster Vac Line
PB Booster Check Valve.
Found a great thread on this on a Chevelle site.
It'll be a good first project for me.
Thanks for the input!!
11" Booster
Booster Sleeve
PB Booster Vac Line
455Olds
Brakes/Hydraulic Systems
Dec 8, 2013 08:16 PM
1956olds88post
Aug 22, 2013 06:33 PM
elcaminodave
Aug 9, 2009 04:57 PM
