Manual Drum to Power Disc Conversion
Old May 26, 2012 | 07:56 PM
KDV's Avatar
KDV
Greetings everyone!
I'm new to the sight, and I apologize if there's already another thread I haven't found that covers this.
I'm the proud owner of a '72 Cutlass Supreme with manual drums. I'd like to convert to PB disc/drum.
I've been reading some horror stories about Power Drums to Power Discs, how horrifying is it to go from Manual to Power?
Would I be better off trying to whiz in the corner of a round room?
Thanks for any input!
Old May 26, 2012 | 08:13 PM
501Paratrooper's Avatar
Joe Padavano has posted a great thread on this.
https://classicoldsmobile.com/forums...sk-brakes.html
Old May 26, 2012 | 08:24 PM
KDV's Avatar
KDV
Thanks Paratrooper!!
I didn't know I'd have to replace rims too.
I may just wanna start with a booster and try Power Drums for a while.
Thanks again!
Old May 26, 2012 | 08:33 PM
2blu442's Avatar
The only rims you would have to replace is if your SSI's are the earlier 14X6" wheels and then not every year of manufacture. For your vintage they should be 14X7's and those will work fine on the disc brakes.
Not a difficult swap, and for something you drive much I think its a nice upgrade.
John
Old May 26, 2012 | 08:49 PM
KDV's Avatar
KDV
Thanks John! Love this site BTW!
I'll hafta get the measuring stick out tomorrow.
If I do just go with Power Drums...
I need a booster and a master cylinder, correct? Aren't the M/C's different bores for power and manual?
Old May 26, 2012 | 08:53 PM
2blu442's Avatar
Booster yes, but I thought the master cylinder was the same for manual drum & power drum. Someone else who knows for sure will have to speak up and verify this for you. John
Old May 27, 2012 | 08:02 AM
KDV's Avatar
KDV
Appears that m/c is 1" bore, same for Power Drum/Manual Drum.
Looks like I'll need an:
11" Booster
Booster Sleeve
PB Booster Vac Line
PB Booster Check Valve.
Found a great thread on this on a Chevelle site.
It'll be a good first project for me.
Thanks for the input!!
455Olds
Brakes/Hydraulic Systems
Dec 8, 2013 08:16 PM
1956olds88post
Aug 22, 2013 06:33 PM
1carsick
23
Oct 2, 2012 05:50 PM
elcaminodave
Aug 9, 2009 04:57 PM
crazyiball
Jan 18, 2007 06:40 PM
