busted brake line,,,
Old Sep 8, 2010 | 07:22 PM
1973olds98's Avatar
Well i found out today i kinked up a brake line installing my rebuilt motor,,,What would be the qquickest way to repair this....Would cutting out the bad part and use compression fittings and a new peice of brake tubing work..
Old Sep 8, 2010 | 07:38 PM
1973olds98's Avatar
What size brake line is used on a 73 olds 98
Old Sep 8, 2010 | 07:39 PM
Run to Rund's Avatar
Don't use compression fittings with "olives" as they aren't for high pressure and reliability. The best would be to measure the line you kinked, and buy a pre-made replacement from NAPA or Carquest. They are cheap and come with flare fittings and nuts already done for you. It is a hassle to cut the liine and make your own flare fittings even if you already have the double lap flaring tool.
Old Sep 8, 2010 | 07:42 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I have done it and it has to be a double flare. A new line is way better since they tend to get old and rust. Use a tubing bender and don't try to make any sharp bends.
Old Sep 8, 2010 | 07:47 PM
1973olds98's Avatar
so car quest makes pre made replacements,,,,i didnt know that
joe_padavano
Apr 12, 2015 05:59 AM
rocketraider
Mar 12, 2013 08:23 PM
Delta88Vert
22
Aug 12, 2012 08:17 AM
SkylinesSuck
Sep 5, 2011 05:58 AM
aholiday
Body work
Jul 15, 2009 06:05 PM
