brakes which power booster
Old Aug 3, 2021 | 05:05 PM
willj's Avatar
hello , was wondering if any body knew what year booster and master cylinder would fit on my starfire , just want to change to a daul mast cylinder ., thanks fror any help , will
Old Aug 4, 2021 | 10:20 AM
sysmg's Avatar
What year Starfire? Are you keeping original drums front and rear? For 65 and 66 where you are keeping your drum brakes I believe you can keep the original booster and use a 66 Cadillac dual reservoir master for front and rear drum brakes. You may find part numbers in other posts on this forum.
For non 65-66, I am not sure.
Old Aug 4, 2021 | 10:23 AM
sysmg's Avatar
See this thread for more detailed info:
https://classicoldsmobile.com/forums...ooster-131299/
Old Aug 6, 2021 | 09:46 AM
willj's Avatar
yes my starfire is a65 ,and i am going to keep the 4 drum brakes , i may have the booster rebuilt , where it is as hard as a rock when pressed on, i thank you for your info and help, will.
willj
Brakes/Hydraulic Systems
May 23, 2021 06:42 AM
bluecab
Apr 15, 2015 05:27 AM
borrone821
Oct 4, 2014 07:13 AM
STLCRZY
Mar 10, 2014 07:36 AM
eddieunderground
Nov 26, 2010 09:46 PM
