brakes which power booster
hello , was wondering if any body knew what year booster and master cylinder would fit on my starfire , just want to change to a daul mast cylinder ., thanks fror any help , will
What year Starfire? Are you keeping original drums front and rear? For 65 and 66 where you are keeping your drum brakes I believe you can keep the original booster and use a 66 Cadillac dual reservoir master for front and rear drum brakes. You may find part numbers in other posts on this forum.
For non 65-66, I am not sure.
yes my starfire is a65 ,and i am going to keep the 4 drum brakes , i may have the booster rebuilt , where it is as hard as a rock when pressed on, i thank you for your info and help, will.
bluecab
Brakes/Hydraulic Systems
Apr 15, 2015 05:27 AM
eddieunderground
Nov 26, 2010 09:46 PM
