Brake Upgrade
Old Sep 18, 2008 | 05:49 AM
citcapp's Avatar
Brake Upgrade
Does anyone know if later model self adjusting backing plates and drums will fit my 57 Oldsmobile. When the new 455 I would like to upgrade along with redoing the brakes. Later when I figure out how to duct my heater to the drivers side of the car and do away with the air box on that side I will add a dual cylinder brake system.
Thanks in advance.
Old Sep 18, 2008 | 07:07 AM
citcapp's Avatar
Brake upgrade
Ok, after a little research I have found out the Oldsmobile starter putting self adjusting brakes on their products in 1959. So next question with the 59 version brake backing plates and drums fit my 57 Olds with the 455 running so strong I want to upgrade if I can.
Old Sep 18, 2008 | 07:48 PM
59-59-59's Avatar
I had this same idea of putting self adjusters in from a 'later' car.. "Later" meaning 1962 as I believe that was the first year they had self adjusting brakes. I even put a 'wanted 1962 brake adjusters' thread with no luck on this website. Trust me - I just did the entire brake job on my '59 and there is no self adjusting brakes on them. I want to put them on my 59 cause its a pain to adjust them every 2 to 3 months
Old Sep 18, 2008 | 08:34 PM
citcapp's Avatar
Hate to here that. I feel the same way and with the power I now have with the 455. I am even more concerend. We have a few pull t=yourself yards around here with early 60 GM. the bodys are mostly parted out but their are some frames, axles. and front ends that can be identifed. I guess its time to take pictures of mine, and measurments and muck around and see what I can find out. I need to do a full break job so I guess now is the time. I will let you know what I find out
toms1966rgtop
Brakes/Hydraulic Systems
Feb 28, 2010 06:45 AM
Aceshigh
Sep 5, 2009 06:34 AM
toms1966rgtop
Jun 1, 2009 12:17 PM
65Delta88
Nov 5, 2008 09:30 AM
citcapp
Oct 8, 2008 07:23 AM
