Brake pads
Old Aug 12, 2023 | 12:54 PM
philv1983's Avatar
Brake pads
So my 72 was converted to power disc, I believe they did the cheap right stuff kit. Not sure what pads are on there, but it squeals everytime I hit the brake. What pads should I go with to eliminate the noises?
Old Aug 13, 2023 | 07:30 PM
You should use the anti-squeak shims that go between the pads and the caliper. Also, did you cinch the tabs on the ears against the caliper, as directed in the Chassis Service Manual? Did you apply grease to the sliding surfaces between the calipers and the brackets?
Old Aug 13, 2023 | 08:03 PM
philv1983's Avatar
I didn't install the kit. It came on the car. She sounds like a semi every time I touch that pedal though. Gonna order some pads as soon as I figure out what's on there and redo everything.
RockAuto
Aug 19, 2021 04:28 PM
Michael 12345
Dec 14, 2019 07:50 PM
pcard
Nov 3, 2015 08:22 AM
Magna86
Jul 20, 2015 08:46 AM
oldgold
Brakes/Hydraulic Systems
Apr 23, 2012 06:46 AM
