Brake line fitting /thread 66 F85 330cui
Old March 15th, 2017, 03:13 AM
Haidda's Avatar
Hello guys,
can anyone tell me what fitting/thread the break lines on a 66 f85 330cui have?
The one from the master cylinder to the T-piece (or whatever it is called).
Thank you very much, greetings from Austria
BR Daniel
Haidda is offline
Old March 15th, 2017, 06:36 AM
Originally Posted by Haidda
Hello guys,
BR Daniel
The tee is called a distribution block. The threads are usually 3/8"-24 on the fittings for 3/16" diameter tube and 7/16"-24 on fittings for 1/4" tube. Note that on later cars with dual-circuit brakes, GM often used different threads on the flare nuts to prevent mis-connections on the assembly line. Your 1966 only has a single circuit brake system, so this should not be an issue for you.
joe_padavano is offline
Old March 16th, 2017, 01:39 AM
Haidda's Avatar
Thank you very much for your quick response. Last but not least: is it a bubble or a inverted flare? I can´t uninstall the line yet to look -> long shipping time and I can´t drive meanwhile!
BR Daniel
Haidda is offline
Old March 16th, 2017, 03:07 AM
chopolds's Avatar
Inverted flare on the old cars.
chopolds is offline
Old March 16th, 2017, 06:40 AM
US-made cars didn't start using metric bubble flares until the 1990s, and many still use the traditional inverted flare. Anything from the 1960s uses inverted flare exclusively.
Old March 17th, 2017, 03:53 AM
Haidda's Avatar
Awsome! Thank you very much....I´m the Olds expert where I live, because.....i´m the only one with an Olds :-)
Haidda is offline
Olds Scott
September 3rd, 2015 11:18 PM
yamahondarider
June 23rd, 2015 07:34 PM
Cincinnati Rick
Brakes/Hydraulic Systems
February 10th, 2015 07:12 PM
harascho
February 10th, 2014 02:11 AM
Flye
July 31st, 2009 04:03 PM
Quick Reply: Brake line fitting /thread 66 F85 330cui
