Brake line fitting /thread 66 F85 330cui
Old Mar 15, 2017 | 03:13 AM
Haidda's Avatar
Hello guys,
can anyone tell me what fitting/thread the break lines on a 66 f85 330cui have?
The one from the master cylinder to the T-piece (or whatever it is called).
Thank you very much, greetings from Austria
BR Daniel
Old Mar 15, 2017 | 06:36 AM
Originally Posted by Haidda
Hello guys,
BR Daniel
The tee is called a distribution block. The threads are usually 3/8"-24 on the fittings for 3/16" diameter tube and 7/16"-24 on fittings for 1/4" tube. Note that on later cars with dual-circuit brakes, GM often used different threads on the flare nuts to prevent mis-connections on the assembly line. Your 1966 only has a single circuit brake system, so this should not be an issue for you.
Old Mar 16, 2017 | 01:39 AM
Haidda's Avatar
Thank you very much for your quick response. Last but not least: is it a bubble or a inverted flare? I can´t uninstall the line yet to look -> long shipping time and I can´t drive meanwhile!
BR Daniel
Old Mar 16, 2017 | 03:07 AM
chopolds's Avatar
Inverted flare on the old cars.
Old Mar 16, 2017 | 06:40 AM
US-made cars didn't start using metric bubble flares until the 1990s, and many still use the traditional inverted flare. Anything from the 1960s uses inverted flare exclusively.
Old Mar 17, 2017 | 03:53 AM
Haidda's Avatar
Awsome! Thank you very much....I´m the Olds expert where I live, because.....i´m the only one with an Olds :-)
Olds Scott
Sep 3, 2015 11:18 PM
yamahondarider
Jun 23, 2015 07:34 PM
Cincinnati Rick
Brakes/Hydraulic Systems
Feb 10, 2015 07:12 PM
harascho
Feb 10, 2014 02:11 AM
Flye
Jul 31, 2009 04:03 PM
