Brake Fluid Gone?
Brake Fluid Gone?
Car is a 1962 Oldsmobile Dynamic 88. The MC is bone dry and I have no pedal.
A quick check at the back of each wheel and of all hoses/lines shows no obvious break/leaks.
Nor is there any sign of lost fluid on the garage floor.
Where and the H could the brake fluid have gone?
Into your brake booster, or, if manual, your firewall insulating pad.
Sounds like a bad master cylinder. It likely leaked out the back.
This would be a great time to upgrade to a dual circuit system!
X2 or 3 on the booster, but I would also pull a wheel or two and just for the hell of it see if they are indeed dry. I have a Land Cruiser that had bad wheel cylinders that showed very little fluid leakage on the backer plated but were wet on the inside.... Tedd
Well, I do not want to sound ignorant, but does a 1962 Olds Dynamic 88 with PB have a booster? If so, where is it located?
I ask as none of the national parts suppliers list such a part, and I have no tank attached to the firewall. My MC mounts directly to the firewall.
The attachment is representative of the MC on my car.
Questions on brake/MC probs:
1 - How do I tell if I have a Bendix or Delco-Moraine unit?
2- In terms of a MC rebuild does it make a difference in terms of parts whether mine is a
Bendix or a Delco-Moraine?
3- Is it possible to do a rebuild of the MC without having to remove the vacuum
booster?
Appreciate some guidance here, as would like to start this project on Sunday. Thanks.
booster?
The Bendix unit is held together by 8 screws, while the Moraine unit is held together by interlocking "fingers" like the units on later cars.
Yes, they are different.
Depends.
For a Bendix unit, you remove the four nuts and remove the M/C from the booster.
For a Moraine unit, you remove the four nuts and remove the M/C from the booster, BUT the piston stays behind, attached to the booster, and the booster must be disassembled if you want to remove it.
Also, there are shims between the M/C and the booster in the Moraine unit, and you need to find and reinstall all of them.
Eric,
Thanks. Your reply is helpful.
Bottom line appears to be that I will have to remove it to ascertain which unit I have.
YOU STATE: The Bendix unit is held together by 8 screws, while the Moraine unit is held together by interlocking "fingers" like the units on later cars.
Where should I be looking for/will I find these "8 screws"?
Bendix Assembled with Screws
Moraine Assembled with interlocking fingers
Moraine again.
Hey, that's what we're here for.
All of this information is in the Service Manual, but it is not laid out in a way that makes these distinctions clear, so it is entirely reasonable that you may need a few pointers.
Once you know what you've got, the manual should be able to guide the rest of the job.
In fact, I remember reading about the disassembly of the Moraine unit, but the text and pic did not make a whole lot of sense to me. Now it does!
ANOTHER QUESTION: Is there a separate rebuild kit for the vacuum cylinder?
My thinking is, while I am in there I might as well rebuild both the MC and vacuum cylinder.
UPDATE: Removed both MC and the booster. Booster is a Moraine single diaphragm unit. Disassembled both.
Saw nothing obvious saying "fix me!"
Have sent combined MC and booster off for rebuild.
Awaiting return so I may install.
The booster did indeed contain fluid. It is now being rebuilt.
Interestingly, the rebuilder reports that while I do have a Delco-Moraine booster, my MC is a Bendix. I find that a bit odd as I did not think "mix & match" was an option; especially given the 2-bolt/4-bolt differences in the MCs?
Here is a pic -
Here is a pic -
I am able to report that I do once again have brakes! The booster/MC combo has been rebuilt and reinstalled. I also replaced all the hydraulic brake hoses while I was at it.
This job was, to say the least, a royal pain. The most difficult task was getting the MC brake line fitting back on. Absolutely absurd the time and effort required to accomplish that!
I ended up separating the MC from the reinstalled and mounted booster to get the brake line and fitting to line up with MC port. Then it took a while to figure out how and the heck to once again get the MC mated to the vacuum assist booster. I was more than surprised how much force was required to overcome the pressure exerted by the MC piston.
Luckily, all is back together now and working as intended!
cfair
Brakes/Hydraulic Systems
June 8th, 2009 12:37 AM
