Brake Fluid 55 Olds 88
Old Jul 12, 2009 | 12:34 PM
Pookster6's Avatar
Hi, guys. Another elementary question - where do I check the brake fluid on my 55 Olds 88? I think it is a small dipstick on the drivers side by the steering column with a little triangle on top that screws out. Is this correct? ALso, what type of brake fluid should I be using? Thanks!
Old Jul 12, 2009 | 03:44 PM
citcapp's Avatar
your correct that is the master cylinder for your car. Use Dot 3 brake fluid
Old Jul 13, 2009 | 07:22 PM
Pookster6's Avatar
Great, thank you for taking the time to answer!!
Old Apr 29, 2021 | 06:48 AM
BeantownEnglish's Avatar
So I’m late on this thread but I’m also having issues locating the master cylinder fill on my 55 olds 88. I have no dip stick on the drivers side. Any ideas guys?
Old May 2, 2021 | 09:10 PM
Tedd Thompson's Avatar
It is there if you are talking about a power brake set up. It is below the steering column and slightly to the rear. doesn't look like a engine dip stick but a small flat spade thingy threaded top on the master.
It's a bit hard to top off with out ether a long skinny funnel or some clear plastic tubing attached to a bottle (like what is used in a diener for ketchup) . Don't drip it on your paint or it will remove it....Tedd
Old May 3, 2021 | 02:58 AM
ignachuck's Avatar
Frank Ignachuck
I use one of these:
If you google "tatoo bottle" you'll find them. Tedd's diner ketchup bottle suggestion works well also.
Phil Perlini
Brakes/Hydraulic Systems
Jul 30, 2020 03:51 PM
rodan
Mar 29, 2016 04:33 PM
timothypaul
41
Feb 12, 2015 09:49 AM
ekamm
Jul 31, 2010 08:12 PM
Jerry Hamlin
May 4, 2009 07:11 PM
