Brake fluid resevoir?
Old Nov 10, 2009 | 08:47 AM
ekamm's Avatar
This may sound crazy but I'm having a hard time finding the brake fluid reservoir on my '55 super 88.
Old Nov 10, 2009 | 11:06 AM
citcapp's Avatar
Its next to the steering column in the engine bay down low there is a small screw on cap on a tube sticking up from the reservoir its mounted on the front of the power brake cannister. Use a flashlight its there
Old Jul 29, 2010 | 02:57 PM
rv21350's Avatar
Not only is it hard to find its almost impossible to fill. If you have it on a hoist you can see it easily.
Old Jul 30, 2010 | 02:31 AM
Yellowstatue's Avatar
It's right there, under your feet ...I fill mine on a '57 with a small plastic brake fluid bottle, about six ounces that I bought in Lansing and I just refill it when I need to top up my '57 brake fluid The top part of that screw in rod has two small holes that are air vents...so make sure they are cleaned out
Old Jul 31, 2010 | 08:12 PM
Tedd Thompson's Avatar
brake fluid resevior
Ekamn, It is at the bottom of the steering wheel column on a 55 and I fill mine with a plastic bottle that you use to put ketchup on your fries at the local burger place. If I can find it I add a little plastic tube that makes it easier still ....Tedd
Joeypete
Brakes/Hydraulic Systems
Jan 20, 2010 07:09 AM
cfair
Jun 8, 2009 12:37 AM
southcarolina803
Sep 28, 2008 03:06 PM
ztim
22
Jun 29, 2008 05:13 AM
dynamic88
Jul 28, 2007 08:04 PM
