Brake fluid
Dot 3 or 3-4 if the line are dry did you change them out? are the wheel cylinders also dry? if you did not change the lines you could have rust in them as well as the cylinders. You might want to look things over before you start adding brake fluid other wise I would start with a quart. IMO
