brake drums
Old Nov 15, 2011 | 02:11 PM
willj's Avatar
brake drums
hi, ihave some brake drums i want to clean up ,to use them until i can get some new ones, any suggestions on what grit sand paper could be used , or any ideas, to clean the drum surfaces , i have new brake shoes, thanks to all, will.
Old Nov 15, 2011 | 02:16 PM
AZ455's Avatar
1974 DELTA 88
After machining a drum I usually use something rather fine. I'd try to use the finest you can that will clean them up. How bad are they? You may want to see if you local Napa or someplace can turn them for ya.
Old Nov 15, 2011 | 04:13 PM
There will be a minimum thickness cast onto the front of the drum. Get out a set of calipers and see if you're past the tolerance. If you're just at it or past, just get new ones.
Assuming they are good, use some 400 or 600 wet/dry sandpaper to clean up the inside surfaces, spray with brake clean. Blow clean with air, then respray with brake clean. Have fun!
317rcampbell
Dec 29, 2011 04:15 AM
coppercutlass
Brakes/Hydraulic Systems
18
Dec 6, 2011 01:00 PM
my69olz
Jul 2, 2009 08:27 AM
skaboy 40
Apr 12, 2007 08:22 AM
jskosk919
Jul 4, 2006 08:31 PM
