Brake booster not good ??
Old Jul 10, 2024 | 02:37 PM
Tancuda's Avatar
Hi, due to my hard brake pedal, was checking my (new) booster, with engine off I pump the brake 4-5 times and hold it,
I start the car and the pedal drop about 1/2", do you think it's normal ?
And after letting the engine idle 2 minutes, I shut off the engine, I slowly remove the check valve on the booster and I ear nothing !
I think I should ear some air escaping right ? And yes I have vacuum on that hose and check valve is ok. Did check vacuum with booster hose installed and removed and same vacuum on engine so I don't have a vacuum leak there.
Could that booster be internally not good without a vacuum leak ?
That booster is new and also the master cylinder and all brake hose and line.
Any advice ?
71 442
Thanks everybody
Tancuda
Brakes/Hydraulic Systems
May 12, 2024 11:31 AM
Tancuda
Sep 28, 2023 02:25 AM
piperman60
Jun 24, 2021 01:19 PM
alexrains
Nov 11, 2016 06:50 AM
TheBigBlueBoat
Mar 21, 2016 10:24 AM
