brake backing plates - help!
Old Oct 30, 2010 | 01:23 PM
lvelocci's Avatar
hello all,
restoring a 72 cutlass 2 door and it has 4 drum brakes - would like to keep original if possible but can't seem to find brake backing plates.
The ones I have on the car (original) have some small holes in them near the top. I was thinking about cleaning them as best I can (wire wheel etc.) and then patching the holes with fiberglass or welding.
Any thoughts on this? or has anyone done something similar?
is it a big problem to leave them untouched until I find some used ones somewhere?
Old Oct 30, 2010 | 01:36 PM
Originally Posted by lvelocci
hello all,
Backing plates from any 1964-1972 GM A-body cars with drum brakes will interchange. They should be plentiful, particularly with most folks converting to disk brakes.
Old Oct 30, 2010 | 02:36 PM
2blu442's Avatar
Are you needing these for the front or rear of your car? I may have something, where are you located? John
Old Oct 30, 2010 | 05:44 PM
lvelocci's Avatar
I am in Halifax NS, Canada - I have called around and most can't find parts and are suggesting I move to disc brakes. Is it a huge job to do? never worked on disc brakes.
would be interested in understanding process if someone has done before.
dnmfranco
Apr 9, 2014 08:52 AM
501Paratrooper
Brakes/Hydraulic Systems
Jun 20, 2012 11:35 AM
oregontopcat
Paint
Apr 20, 2011 06:39 AM
oregontopcat
Apr 14, 2011 08:28 PM
lvelocci
Oct 24, 2010 02:58 PM
