Brake adjustment
Old Mar 16, 2024 | 04:07 PM
griffey57's Avatar
Brake adjustment
How tight should drum brakes be adjusted on our classic oldsmobiles?
Old Mar 16, 2024 | 05:00 PM
I loosen the adjustment until I can get the drum over the shoes. Then I tighten the adjustment through the backing plate until the shoes drag on the drum. Finally, I loosen the adjustment just enough so the shoes don't drag.
I've never checked the CSM procedure. Just the way Oldsguy taught me.
Old Mar 16, 2024 | 05:50 PM
The self adjusters will tighten the shoes until they drag slightly. This minimizes pedal travel. I usually manually adjust until there is a light drag.
Old Mar 16, 2024 | 05:53 PM
This is what I do.
Old Mar 16, 2024 | 05:57 PM
This what I do.
I learned that from my high school auto shop teacher in 1975, so it's worked for me for just about half a century.
Cool teacher. He had a 1969 (?) Dart GTS.
Old Mar 16, 2024 | 07:44 PM
I learned it from my dad, around the same time frame. We had just purchased my first car, a 67 Cutlass that my aunt previously owned, and we were going through all the safety items, wheel bearings, and a tune.
Old Mar 16, 2024 | 08:19 PM
...He had a 1969 (?) Dart GTS.
That 340 was a sweet little motor.
Old Mar 16, 2024 | 09:33 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Guys, I think his car is a 57 Olds without self-adjusting brakes. Jesse gave some good advice. He had a good mentor. I think self-adjusting brakes started in 1963.
Old Mar 16, 2024 | 09:55 PM
They still need to be adjusted to where they just barely rub. Relatively the same amount at all four corners.
Old Mar 17, 2024 | 06:20 AM
Good point, I missed that. As with my 62, adjustment will be needed periodically. And as stated above, a slight drag is preferred.
garyfoust
Mar 25, 2022 05:13 AM
slw0501
Brakes/Hydraulic Systems
Oct 12, 2015 01:55 PM
Kiwiolds
Mar 14, 2013 09:12 AM
Wilson05
Apr 7, 2009 03:33 PM
Colorado Olds
Apr 5, 2008 07:33 PM
