Booster and master cylinder correct finish
Old May 22nd, 2024, 03:17 PM
mrb2872's Avatar
I'm upgrading from manual to power brakes on my '71. I'm curious on what the correct factory finish is for the master cylinder and booster. I would have expected yellow zinc, but I'm seeing a lot of variances on Google searches of 'original' engine bays. Black, grey, more of a silver. Maybe it was a lottery of whatever was in the bin that day for the guys to put on at the factory?!?
I was looking through a bunch of the other threads about this change to make sure I've got what I need. It sounded like just adding the booster to and reusing the existing master cylinder was ok?
Thx.
mrb2872 is offline
Old May 22nd, 2024, 05:18 PM
Gary
VC455's Avatar
The booster was finished in zinc dichromate. This gives a rainbow look to the surface.
It's not a durable coating. If you have a fluid leak, the dichromate will not prevent rust.
What I found to work well is to plate first with nickel and then do dichromate for the final layer. That way the booster is protected from rust and the dichromate stays looking fresh.
VC455 is online now
Old May 22nd, 2024, 06:30 PM
70Post's Avatar
The dichromate that Gary mentions above will be a gold or "yellow" color/tint. It'll probably be a lot brighter and "colorful" compared to the plating on an original booster but it will be considered "correct" IMO. Black or silver.....no. Black is indicative of possible auto parts store replacement booster (cheap finish to keep the price down) and silver isn't correct for your era. It wasn't a "that's what's in the parts bin" situation as you mentioned in your original posting.
As far as the master cylinder.....black or cast iron. I say black but others may argue bare (which would be a cast iron paint if rust is a concern). Cap should be dichromate (ie - yellow/gold).
Can you post a good pic of your current master cylinder??? Can you see if it has a two letter code stamped into a machined half-circle-or-so pad on the "nose" of the master?
70Post is online now
Old May 23rd, 2024, 05:07 PM
mrb2872's Avatar
I'd take a pict, but it's up at a shop getting some carb work done. Thanks for the confirmation.
mrb2872 is offline
4+4+2=10
Brakes/Hydraulic Systems
19
January 13th, 2022 06:31 PM
Fun71
February 15th, 2020 02:20 PM
Kensey
September 14th, 2018 04:53 AM
Rustbucket2
March 11th, 2016 07:11 AM
STLCRZY
March 10th, 2014 07:36 AM
Quick Reply: Booster and master cylinder correct finish
