Bleeding brakes on 78 Delta 88
The brake pedal on my wife's 78 Delta 88 Royal has gone to the floor. I checked the master cylinder and it was low - do I fill both sides or just the front? Filled the front and pumped the brakes, still goes to floor so I'll attempt to bleed them this afternoon. Does anyone know what size wrench I need to use on the bleeder valves? Any other things I should check that may cause this:
Chris
Chris
Check aroung each wheel and look for fluid on the ground, maybe a blown wheel cylinder or seal went bad in the master cylinder, or blew a rubber hose at one of the wheels or the hose from the hard line to the rearend, Something caused this problem. Fix that firs then we can talk about bleeding.
