Anywhere I can get a Full Disc Conversion Kit with Booster?
We have a 1957 Oldsmobile Super 88 4-Door and where wondering if anyone here knows where we can get a full front and rear disc brake conversion kit with booster. We recently ordered from ClassicDiscBrakes without reading the reviews and now were trying to get our money back. Just wondering if others know of a better site to get a full conversion kit with booster. We've allready looked on websites like Jegs, Summit, and Caddy Daddy. But their never full kits, just partial.
Thank You.
Thank You.
Disk brakes are going to be a pretty big undertaking on your car. First off the original master cylinder is mounted under the floorboard. Disk brakes will require a firewall mounted master cylinder which will then require a swinging brake pedal. I believe you can buy brackets for the front from Scarebird. It will require fabricating brake lines and probably some brackets. I have never seen a full kit to do this conversion and am pretty sure nobody makes one.
Joe, have you ever installed power brakes on a 57. Have you ever owned a 57. A street rod is a totally different thing where you are fabricating everything from scratch. Go ahead and take your best shot.
I have zero experience with the 50s cars. I still don't understand what changing to disc brakes has to to with moving the master cylinder. This isn't a bolt-in, so fabrication is obviously required in all cases. Lots of 1950s cars have been built with upgraded M/Cs under the floor.
I suppose anything is possible for a price. I have never seen anybody put the master cylinder under the floor. I agree it would look a lot better. All I have ever seen is the use of a swinging pedal which I would never do unless I was building a restomod.
I know people want to have modern disk brakes. But it's so much work for so little benefit. If you drive the speed limit, don't have to do multiple 60-0 full emergency stops in a row, then drum brakes perform just as well. They would have to be in factory shape, but that's probably easier to do than doing a disk brake conversion.
In my opinion, my 57 olds stops great I have replaced all brake components to brand new with no issues. I will drive this car anywhere. Every one is drinking the Kool aid that drum brakes are taboo. It's just not so, maintain your brakes and they will work just fine!!
Z-Fitch
Brakes/Hydraulic Systems
September 12th, 2012 05:00 AM
