Another disc brake conversion question
If you're planning to convert your non disc car to disc, why not just go with the complete setup that works? I'm suspecting that $$ are a factor. If that's the case, find a 70-72 Cutlass/442 that is being parted and offer a bottom dollar on the front end brake package complete. You'll end up rebuilding it for a fraction of the cost of new. I'm pretty sure you'll also have to change your master cylinder and possibly booster too.
ILT has the entire kit (new) for 675.00 I'm sure that if you shop around you'll find a new one at the price you can afford. Or maybe you'll luck out on one you can rebuilt. I looked at Year One and OPGI. they were 1200 and 800 bucks respectively. They also show replacement proportioning valve and lines. Apparently it's not as simple as just bolting a few things together (I'm assuming)
I believe this is the thread that was referred to by redoldsman https://classicoldsmobile.com/forums...onversion.html
The 1973-up spindles are taller and use a different ball joint taper, so they do not interchange. Also, the caliper mount and the steering arm are integral to the spindle forging, so NOTHING interchanges. As noted here in the past, you can simply machine the bosses on the drum brake spindles to turn them into disk spindles. Everything else you need is available new (calipers, caliper brackets, rotors, etc.).
This website covers first gen Camaro brakes, but the spindles, rotors, calipers, and brackets are identical to those on 64-72 A-body cars. Only the bolt-on steering arms are different. Page down and you'll see the machining needed to convert drum spindles to disk.
http://www.pozziracing.com/brakes.ht...Drums_to_Discs
This website covers first gen Camaro brakes, but the spindles, rotors, calipers, and brackets are identical to those on 64-72 A-body cars. Only the bolt-on steering arms are different. Page down and you'll see the machining needed to convert drum spindles to disk. http://www.pozziracing.com/brakes.ht...Drums_to_Discs
No, just use your existing ones. They bolt on. The drum and disk steering arms are the same. The difference is between F-body and A-body cars.
Joe, I talked with a guy this morning who says he put a set of 1973-77 A-Body spindles on his 1971 Vista Cruiser. He said he changed the ball joints to match the spindles and this setup lowered the front end by about an inch. I'll try to get more details from him.... John
Thanks for all the great input guys.
Machining the bosses sounds like the way to go.
I am curious about the replacement ball joints
the fella did for his VC conversion....
If anyone needs this '73 Cutlass S,
pm me, and I will sell it as a whole for $400.
Quick note, pretty much rust free front fenders,doors,hood.
The bumpers are really straight, and would polish up nice.
Was an A/C bucket car w/rear glass defrost.
I will post pics on cars for sale.
Given how easy it is to install stock discs, I fail to see the advantage.
Mocephus
Oct 1, 2021 09:45 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
Mike Hateful
Oct 3, 2011 06:58 PM
smcurro
Suspension & Handling
Dec 8, 2009 07:09 PM
