72 Supreme disc brakes
Old Oct 14, 2007 | 10:08 AM
Chumley's Avatar
Is a 72 Cutlass Supreme power disc brake system supposed to have the proportioning valve included as standard from the factory? I have to replace the master cylinder and noticed it does not have the valve.( at least it is not near the M/C where you would expect it. I have driven the car enough previously and have not experienced anything unusual with the braking. I'm not even sure if it is the original vacuum booster M/C setup. Are the brake line threaded fittings standard size over a range of years? I'll have to take the cylinder in and match it up when I get a new one I guess. Thanks, Chumley
Old Oct 15, 2007 | 06:30 AM
ALL disc brake systems have a proportioning valve. Starting in 1971, GM used a combination valve that incorporated the proportioning valve and the residual pressure valve into the distribution block. The combo valve should be bolted to the frame directly below the master cylinder.
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
<c. larson>
Cars Wanted
Sep 23, 2006 05:57 PM
Det313
Jun 22, 2006 04:16 PM
