72 disc brake backing plate
Old Sep 7, 2011 | 07:19 PM
  #41
Might as well - goes to DEFCON 1
Originally Posted by Lady72nRob71
Looks like you need 2 of Moog K6629 sway bar link sets. They have the metal rod, bushings, and nuts. I got mine from rockauto for 9 bucks a set. I knew yours were gonna be crappy!
Any other things you might have foreseen over on the dark side Master Vader? I'll see if I can order them through NAPA, thx for the part number. Hey do you know if rockauto ships to Canada? They have some darn good prices that might be lower to buy and ship than buying here..
Now if your control arm bushings are as bad......................They aren't, nah nah nah nah na na....
What size hammer are you using on the spindles? A small sledge (3lb) is needed.
Yes, that's what I found out. Going to buy one tommorrow. I also found out that you have to whack it good. I guess the metal should take it. If not I will have to buy a new spindle. FWIW this car originally started life in ONT Canada - a known rust belt. And it did it's fair share of winter driving in AB too. I'm not surprised that this is happening.
A lot of little whacks won't phase it
....So LOVE me tender would be the wrong approach.
You realize that I've been bitten and am now fully infected by the might as well bug, don't you? Now I might as well clean up the LCA and UCA, the air dam, and what the heck, I'm going to do all the pitman, idlers, shafts and ball joints now. Why wait?? Talked to my neighbor tonight (ex wrench puller - in training to be a cop) and he says it just makes sense to do all this once instead of taking it apart again. Wish I'd started in July or August though. This might take a month to get done.
I think I'll also do the back brakes. I need to take the wheels off anyway so I can detail them and have them rebalanced. It will also make it easier to bleed the system when the time comes..This time I plan to put the raised white letters out instead of having blackwalls showing. Then.......I need to pull the rad and have it re-cored. While I'm at it I may as well put in my new water pump, fan shroud, fan, fan clutch, change the coolant, replace all the heater hoses, backflush the system, and do an oil change. Then I'm going to drop the bumpers, install my new grills, install my cutout bumper. I'll get the tips installed in the spring. I'm starting to live in a fantasy world aren't I??
Old Sep 7, 2011 | 07:23 PM
  #42
Lady72nRob71's Avatar
You forgot to mention the radiator support. I bet it needs repainting like mine...
(another grenade tossed into the foxhole)
Yep, rockauto ships worldwide. Look for the discount codes I listed in the announcements.
Don't forget your control arm bushings.
Old Sep 8, 2011 | 07:32 AM
  #43
You forgot to mention the radiator support. I bet it needs repainting like mine...(another grenade tossed into the foxhole)
Actually, it's in really good shape and doesn't need any work at all. What I will add to the list is refitting the hood so it's perfectly flush at the cowl area. Right now it's raised about 3/8" and also needs to come forward about 1/4". But I will add: Oh yeah! Forgot that I need to install my rear sway bar, boxed control arms and axle braces to complete the upgrade to FE2. That would work best while the car is elevated, right?
Yep, rockauto ships worldwide. Look for the discount codes I listed in the announcements. That's good news. I'm going to put together a comparison cost spreadsheet for rockauto and NAPA. Have to factor in shipping for rockauto, but I'm betting even with that it will be cheaper than buying local (shudder).
Don't forget your control arm bushings. "Those are not the bushings you are looking for Luke"....
Old Sep 8, 2011 | 04:24 PM
  #44
Bought a BFH today
Status report:
Bought a BFH today, + stabilizer link kit. The BFH is only 2.5 lbs but has a rubber grip and the shaft/head are all one unit. Lifetime warranty. $10.00, not bad - really easy to hold and swing.
The link kits were 9.00 each. Inner grease seals 4.50 each. Stabilizer bushings: I'm thinking 1" but am not sure. Rob you said the bar is .937? Only one end is square - the other is round. Does that make a difference? Maybe I should go smaller? I measured the ovaled out bushings and they look to be about 1". If I buy 15/16" that may be a better fit considering there was a little wear on the stabilizer bar and I want it to fit snug. What do you think?
Introduced the BFH to the ball joints on the LCA. Whack Whack Whack POP.
Then the upper ( a little more stubborn) 6 Whacks, then POP. Out came the spindle. Cleaned it up and painted. Looks amazing. Only thing left to do on this side is clean the control arms, replace BJs, and install new shocks. May as well do the shocks and BJs all at the same time.
Starting disassembly of Drivers side.
This side is fighting even harder than the passenger side. Thought I was going to break my 3/8 hex taking out the caliper bolts! Took off the caliper and mount, backing plate. Started working on the caliper. Now that I know what to do, pretty easy. There was no gasket between the spindle and the hub. How necessary is it? I have the one from the other side and could probably make a set from some gasket material.
Problem child bleeder screw was there again. So I torched it and tried to unscrew it. The head sheared off in my socket. Tried to drill it and easy out, but no dice. Called EBC and they will machine it out and retap it for about 114.00. So I called NAPA and ordered a replacement for 33.00
Put final coat of paint on stabilizer. It could pass for new.
Checked out rockauto. Made a list and went shopping. The parts came to 110.00 Shipping was 106.00. I did a double take. They ship from different locations. So one group of parts was costing 30, another 25, 27, and 28. That's just retarded, I can buy the same parts here for the price it costs to ship. So I set it up for a US address and the price to ship came from 110 to around 35.00, so you guys down in the US count your blessings on car part pricing and shipping. I don't get the reason it costs so much to cross border ship.
I thought it would be a great idea to drive down, install all the parts on my car and then drive it home. Oh yeah, it's on jack stands with no front brakes......maybe I'll check out otterzone or O'Reillys , PepBoys?
RE: Steering shafts, collar, tie rods, Pitman arms, center link etc. They attach to the power steering pump and to a bracket on the Pass side before getting hooked up to the steering arms. If I take everything off, can I reuse the pitman arms, center link and just install new grease joints. I think I will replace both tie rod ends and collar because the threads are going to be so buggered up it will be almost impossible to to an alignment. That should also make it a lot easier on the alignment shop. Maybe they'll cut me a price break for all new parts??? wishful thinking.
Old Sep 8, 2011 | 04:59 PM
  #45
Originally Posted by Allan R
Status report:
Thats what the 1972 assy manual said for the square one. What year is yours? Mine is .97" and it has a teardrop shape at the end.
Sounds like a winner. Put a caliper on the bar to see what size it really is. 0.937=15/16".
PICKLE FORK THINGIE BAD, HAMMER GOOD!!!
It must have some purpose - just make some out of a cereal box - thats what mine looked like...
Bummer...
Gotta pay thos customs people somehow. It sux for sure.
You can reuse any of those parts. THe pitman arm is a non-wear item, so leave it on the steering gear. The grease joints are not replaceable but you can remove them and clean them up and check for looseness. Not sure if grease boots are even available. I ordered mine al new and assembled it all yesterday. 4 tie rod ends, 2 adjuster sleeves, one idler, and one center link - 400 bucks worth of 5' long iron hanging from the garage ceiling.
Old Sep 8, 2011 | 05:44 PM
  #46
Cereal Box for a gasket? Are you serious?
Got a pic of your steering you can share? I'll salvage as much as I can from my car. Only thing is I'll have to take the assembly off as an assembly just to work on it.
Re: what year is my car? It's 72, just like Lady. Mine was built On April 7, 1972 - got the broadcast sheet to prove it.
Re: steering parts. I think in the interest of not pissing off the alignment shop, the very least I'll do is put on new idler arms and adjuster collar.
Took back the press today. Figured that I may as well get all the other crap cleaned up first, then I'll do the BJs. I have to drill both uppers. the BJ should just come out right? Maybe a whack on the stud to drive it up through the hole? I'll press out the lowers.
Clean the control arms really good and install the new BJs.
Remove old shocks, take out springs and clean/paint. Put in new shocks and pretty black springs. Tape off the BJs and paint the CAs. Fill BJs with grease and reassemble the front susp/brakes. I think this will keep me busy for a few days.
I'll keep you posted on the steering re-conditioning. Wow $400.00??? I can't afford that right now.
TTYL, thanks for the good info. BTW, Love what you've done in the engine bay. I'll go back and look at it later tonight. We had a 30°C day up here. That's probably mild by your standards - about 86°F.
Old Sep 8, 2011 | 07:34 PM
  #47
Dude, when have I not been serious?
Good timing - I just posted one here:
https://classicoldsmobile.com/forums...tml#post320070
Are you meaning tie rod ends? The idler is the thing that bolts to the fram on the right side.
Look through my thread again for the answers. In theory they should come out that way, BUT do not keep hammering on something that would not move like I did.
Take out the springs???? And NOT replace the control arm bushings? You are SOOOooo close!
I did not want to pay it either, but I found it more enticing than trying to clean up my old ones...
That is comfy weather. We have had several days of it so far and it makes the project MUCh easier.
Old Sep 9, 2011 | 04:31 PM
  #48
Counting my money....
Today was kind of a crap shoot.
Decided to go to pick up my parts and get to work. A comedy of bloopers soon erupted.
1. Got to NAPA - they couldn't find the replacement caliper. So another had to be ordered. Handed over my core. New caliper ends up being 40.00 - not bad. It'll be in around noon.
2. Wife calls me on the cell and says to spin on over to partsource. They have my stabilizer link kits in. Picked them up and headed home.
3. Opened the link kits at home and found one was missing a sleeve. So another one is ordered. Should be in after 2pm.
4. Decided to head over to NAPA after a delayed lunch. Got there at 2:00. You gotta be $hittin' me. They ordered a Left caliper and the warehouse shipped a Right. The calipers do look pretty amazing - they are rebuilt Delco Moraine and have all the proper castings and hardware - just add brake pads. It'll be in tommorrow.
5. Went over to Partsource and picked up the new stab link kit. Checked it on the spot - all the pieces were there - YAY! I win. Got it home and found the bolts were 2 different sizes. So when I go to install them, I'm going to put them in upside down so the nut is on the bottom of the LCA instead of having no clearance like the factory did it.
6. Bought some more paint. Decided I wanted the caliper mounts to be gold. So aside from running around a lot, I didn't get a lot done.
Now that I've seen Rob's 'new' steering assembly I started pricing a new one out up here. Just got a check for 500 bucks from a pension underpayment so it might just happen> either that or I'll dip into my savings a bit.
New stab link kits: Note 2 different sized bolts. Shoulders/thread are the same though. Should snug down no problem. Probably cut off any extra thead hanging down to far. The bolt and spacers are much beefier than OEM, and the nut is 9/16 instead of 1/2"
Just waiting to put in brake shoes and do the CA BJs. I'm very hopeful this will be complete next week. After reading through the CSM on Control Arm removal and install, I'm definitely not going to do that because my bushings actually look good. When I was taking the caliper mount apart, the area under the nut looked like it was originally cadmium plated. Decided to paint it with Gold caliper paint instead of silver.
Here's the sway bar. You can see from the pics one end is square, the other is round. So I've ordered 15/16" bushings for the reinstall.
Old Sep 9, 2011 | 06:09 PM
  #49
66ninetyeightls's Avatar
Land Yacht Captain
hmmm..... I wonder where I heard that before????
Old Sep 9, 2011 | 06:20 PM
  #50
Craig, You know exactly where you heard that before... But remember the only reason I'm buying this is because the bleeder valve sheared off in the caliper and I couldn't drill or get it to easy out. I called EBC and they quoted 114.00 (plus tax). The replacement is an delco moraine completely rebuilt. Includes all seals, piston, bleeder, copper crush washers for the banjo bolt, anti rattle clips and new caliper bolts. Clip in the brakes and it's ready for installation.
If the bleeder had come out peaceful like the other one, the caliper would have been rebuilt for about 7.00 without having to drive all over hells high acres and fighting the ongoing Edmonton construction madness.
Here, I'll say it. Craig - you were right about the price being competitive with your area . I'll post a pic of the new one when I've got all the parts in.
Old Sep 9, 2011 | 09:03 PM
  #51
I want to see your luck with sway bar frame mount bushings. I have a set of brand #3 on order...
Old Sep 10, 2011 | 10:42 AM
  #52
What happened with yours? Wrong set/diameter? I've got Moog bushings on order. They're over at partsource right now waiting for pickup. I'll make a circle trip to NAPA and Partsource in an hour or so. When I get the bushings, based on what you're saying I will take one of the stabilzer brackets with me to see if it fits properly before I accept it. I'll post a pic for you if it's good and give you the Moog number. BTW, the Moog number you gave me for the link kits isn't available up here in Canada. Today has a lot of promise. Both sides are disassembled. Drivers side will be on the cleanup list today.
FWIW, I talked to my Mrs. today about replacing all the front steering components (except the pitman off the steering box). She said, and I quote: "If it's old, just replace it". Then she realized what she had said.... Being a 'sensitive guy' who is 'in touch with his wife's feelings' I reminded her that she would always be '29' to me. Anyway, she approves of the spending spree I may soon be on. I priced the tie rods and both sets of inner/outers are 44.00 each. The center link is about 86.00. Pitman is 41. Adjusting collars are 19.00 each. I may be able to pull this off for around the 325.00 mark (tax in). No shipping costs.
That would also let me get to the lower engine cradle area for cleanup (looks a little gungy right now. I can see how easy it is to get to the 'might as well' phase of this hobby. But, I'm really quite enjoying it. Now about the CAs, you had a ton of working space inside the engine compt. Tell you what, maybe next year when the engine comes out????? and only if it really needs it. OH, you'll like this: My wife and I talked about the engine this morning and she's ok with a total rebuild next spring!!! Time to start planning what I want to do with it!!!
Old Sep 10, 2011 | 12:44 PM
  #53
Stabilizer bushing Kit - Moog K5241
Rob,
Just got back. The stabilizer bushing is a 15/16" although the hole looks a lot smaller. Guess that's so it will hold the stabilizer.
Should compress ok, or if it stays too tall I can shave it a bit. The Moog number is K5241 - comes 2 in the box although its labeled as 1. Cost is 13.95 Have a look
The old bushing does extend below the 2 flanges, but the cutout for the stab is so worn it has about 1/8" of slop when it's on the bar.
The new bushing fits the bracket really well and you can see how much better the fit will be on the stab bar. I tried it and it fits nice and tight.
Compressed with 40 ft/lbs on the 2 bracket bolts should make this just right.
Old Sep 10, 2011 | 02:26 PM
  #54
Land Yacht Captain
You definately have a keeper there Allan!!!!
That bushing looks HUGE for the bracket.
Old Sep 10, 2011 | 04:25 PM
  #55
oldzy's Avatar
iz why I like the Hotchkis billet alum front sway bar bushing brackets... eliminates any and all install issues of stock bushing brackets... squeezing brackets in so bolts can get threaded, etc.
Old Sep 10, 2011 | 05:40 PM
  #56
Bushing squeak - no mouse!
Thx Craig. The bushing does look big, but theres a couple of mm of clearance on the sides of the bracket that will take up some of the bulge. I'm counting on it compressing a lot. When it's snugged down I'll see if there's a gap between the bracket and frame. If there is, I'll shave some of the lower portion till it fits right. BTW the instructions say NOT to put rubber lube ANYWHERE on the bushing or it will squeak. I would have thought it would be the other way around....oh well.
Got everything except the rotor/hub on the DS cleaned and painted today. Partsource gave me a new 7 3/4" bolt for my stab link kit. Things are definitely looking up. I'm hoping to have my car back together before Rob , but we'll see
Old Sep 10, 2011 | 08:14 PM
  #57
This.
https://classicoldsmobile.com/forums...-bushings.html
Set 3 is Moog. Hopefully this will be the last.
So are the control arm bushings old?
Pitman is 41.
You do not need a pitman unless yours is wallowed out. It is a non-wear item.
You should be getting 2 outer tie rods, 2 inner tie rods, a center link and an idler arm. Also a full set of control arm bushings.
Pull the inner fender wells. Will give you a LOT more room.
Why not now?
This will be interesting...
Old Sep 10, 2011 | 08:41 PM
  #58
This.
Set 3 is Moog. Hopefully this will be the last. Did you buy the Moog set that I got? K5241 - they look oversize but they aren't really hard. And they are made in the USA. I'm going to use them no matter what.
So are the control arm bushings old? Ummm, no they are forever 29
Hmmm, that will decrease the cost somewhat. thx! You should take apart your old assembly and chrome the center link. Tell kids it's an early Klingon batlith!
Also a full set of control arm bushings. I can see this is going to be a central theme to this steering/brake build
Nope, next year when the engine comes out.
Why not now? Well, up here in Canada we have only 2 seasons: Winter and Construction. Winter is brutal here; up to 4 feet of snow. I need the garage cleaned up before Nov 1 so my wife can park inside. I don't want to rush into the engine build right now.
This will be interesting... Seeing as how I'm not touching my CA bushings or detailing my engine, yes, it will be. Doesn't really matter to me if you win, you started waaaay ahead of me. If you slack off for about 2 months, I might consider pulling the engine now and doing the control arms
Old Sep 11, 2011 | 06:24 AM
  #59
CONTROL ARM BUSHINGS!
I will be watching for a "what's this sqeaking sound in my suspension" thread from you. When it happens, you will want to ban me from it before it gets started...
Seriously, I was joking about the engine pull. However, since you removed the spindles and springs, the hard part is done.
With the right tools and use of them, the control arm bushings were rather easy, especially the uppers. I went into detail in my thread, so if you follow the instructions, it is easy. Now I found the secrets, I could have them all done in an hour or so.
Still wanna fly me up there?
Actually, my mom is on a train in the Rockies right about now... Must be nice.
Oh - replace the upper control arm mounting bolts - the ones with splines that press into the frame. When those break, bad things happen. Been there done that. Breakage seems a bit common, too, as those are high stress areas.
Old Sep 11, 2011 | 09:12 AM
  #60
Talking I don't understand - Control Arm Bushings???
LOL, could you please be a little more clear about this???
That's the good part, there's absolutely no squeaking at all. I've hired a cat to control the mice population in the suspension area!!
With the right tools and use of them, the control arm bushings were rather easy, especially the uppers. Could I use the ball joint press to get the bushings out/in? I don't have spare metal that I can make into a C thingy. I'll go back and read the front end thread more carefully to see if this is something I can handle, OK??
I went into detail in my thread, so if you follow the instructions, it is easy. Now I found the secrets, I could have them all done in an hour or so. But that was with the inner liners pulled, right? Looks like there are only about 10 bolts holding the liner in - does it just drop out with the suspension out of the way? Not that I'm promising anything, but if it only takes about an hour a side (for me that's probably about 3 hours a side) it might just be like building a better mouse trap.
Still wanna fly me up there? Heck, I'd love to, but I'm investing all my money in parts now . Put Lady back together pronto and drive yourself up here. The weather is changing pretty fast - only going to be a high of around 68 today. You'll need your seat heaters
Oh - replace the upper control arm mounting bolts - the ones with splines that press into the frame. When those break, bad things happen. Been there done that. Breakage seems a bit common, too, as those are high stress areas. Good to know. I just looked; there are 3 alignment shims packed in there on them; so if I do this work I'm going to have to put those 3 back exactly where they were and snug it down. Like you I take pics before for refs. So if they aren't broken or don't break-reuse them? Or just replace on principle?
You are talking about these right?
My hands and fingers are starting to hurt from all that wire wheeling and sanding. Dull achey pain. Time for some Advil, then I'll get back at it. Today I think I'll rebuild the hubs. BTW I found the other gasket on the DS. It was stuck to the spindle under all that grease/crap. I don't think it's there for sealing purposes, it looks more like it's to prevent metal/metal contact on between the backing plate and the steering knuckle. Maybe a vibration or sound deterent?? Can't think of any other good reason to put a gasket there.
I'll add the cost of (upper/lower) CONTROL ARM BUSHINGS for my next visit to NAPA. Going to order the steering components on Monday. As you can see, the Dark side is swaying me down a path I didn't want to originally follow. But I'm starting to feeeeel the Pooowwer. Just tossed my aluminum foil skull cap
Old Sep 11, 2011 | 12:38 PM
  #61
oldzy's Avatar
IIRC, I still have 2 x NIB sets of Moog front upper/lower OEM CONTROL ARM BUSHINGS (not sure on ball joints though) if interested (one 'round' and one 'oval' set IIRC). All new from Rock Auto. I ended up going with all poly bushings from Energy Suspension.
... big nough font der?
Old Sep 11, 2011 | 12:51 PM
  #62
OLDZY, you slay me!! LOL
Old Sep 11, 2011 | 12:52 PM
  #63
oldzy's Avatar
I also have those new from dealership OEM rubber spindle seals. I think I have 6 left. They are tricky to put on... have to glue ( I used grease) to keep them in place when mounting the backing plate. Repos are a gasket material... OEM is rubber.
Old Sep 11, 2011 | 12:57 PM
  #64
oldzy's Avatar
I am your overlord
Old Sep 11, 2011 | 01:00 PM
  #65
Ok I must have pressed a wrong button because the permalink 'posted itself'. Anyway oldzy, ya da font be big enough fer me!!!
There is no difference between 72 Supreme and Sport control arms, so what kind of $$ you looking for? If it costs less to buy from you and ship out here I could go for that. Don't worry about Ball Joints, I have all 4. Ordering steering parts tommorrow, so if you get back to me with a pm on $$ asap that would be cool, although I have to say in advance (and in all honesty) the shipping will probably be the deal breaker?? Thanks for thinking of me...
Old Sep 11, 2011 | 01:06 PM
  #66
Did not know that? I had planned to re-use the originals. Do you know why they had those seals? From what I can see, the inner grease seal should take care of any grease issues, and the rubber seal you are talking about is on the other side of the backing plate. Is my theory (above) right.
OVERLORD??? I don't think so When my wife reads this, she will give your @ss a long distance kick Only 1 overlord allowed / household!
Old Sep 11, 2011 | 01:07 PM
  #67
oldzy's Avatar
I would likely give a better deal than Rock Auto or local NAPA even with shipping included... just so I can free up space in the garage. I have new Moog parts taking up a whole shelf in one of the cabinets where my Chassis Service/Assembly Manuals and resides. I could use that space for dirty **** mags or something.
I have several new parts I never used. ie. Brand new complete set of AC Delco tie rods, Moog sleeves, calipers, complete OEM style brake line set from ILT, etc.
I will get back to you after dindin with some prices... and pics of course.
Old Sep 11, 2011 | 01:14 PM
  #68
oldzy's Avatar
I think it is more of a vibration thing between metal-metal contact. You could re-use them if they are ok. No doubt they are flatter than a pancake like mine were.
Old Sep 11, 2011 | 02:52 PM
  #69
That would be great.
just so I can free up space in the garage. I have new Moog parts taking up a whole shelf in one of the cabinets where my Chassis Service/Assembly Manuals and resides. I could use that space for dirty **** mags or something. Probably the `something`
I`d be interested in the tie rods, sleeves, (idler arm if you have it). The control arm bushings - if I read the post right you have enough to do the whole front end. I`d prefer to help out a fellow Oldsmobiler when possible. Not looking to `part rape`you though.
Actually that`s why I thought they were gaskets . Probably could reuse the old ones but if I can get some new ones Im interested in a set of those. Maybe see if Rob if he would like a set too. Rob, you watchin this...
Old Sep 11, 2011 | 05:52 PM
  #70
Oldzy, one more thing I forgot to tell you. The parts at NAPA I can get with corporate discount. That brings the cost way below what the average guy pays. Eg: the brake pads I bought were premium: Retail 83.00 corporate cost 55.00. Actually, all the prices are listed in permalink 52. Only thing I didn't post was the idler arm. Anyway, I'm looking forward to your pics and $$ comparison.
Old Sep 11, 2011 | 06:02 PM
  #71
oldzy's Avatar
Some pics...
K5161's on far left are rear uppers. I tried to install one, but was too tight, then installed poly instead.
K5149's are the oval/round ones for bottom, two bushings per box.
K5196's are the upper bushings, 2 per box (note that the 4 on top are extras when I bought my pair of Moog upper arm shaft kits)
K5103/5108's are upper/lower ball joints.
***all bushings say Made in Mexico on boxes... except for ball joints
Extra set of front ES poly bushings. This kit has the oval bushings on one side of the lower front arm. I used the all round kit instead after I got nicer control arms from Glenn Lever. No grease included (used it on my Currie Currectrac rear lowers), but I believe I have an extra tube somewhere.
These older style front upper shafts I 'believe' are new but not sure (bushings were/are though). Glenn Lever removed them b/c I mentioned to him I was going to use my own Moog K5250 shafts and poly bushings.
Edelbrock and PST adj sleeves. Edelbrokes seem to be rusting a bit already through the zinc plating. I mounted them a few times, then removed them, as I already have Hotchkis ones. The PST ones look identical to Hotchkis ones, and are actually purtier (both are powdercoated). Below that are four of those rubber OEM spindle/backing plate gaskets mentioned. One needed on each side.
ES2004S tie rod sleeves, 1 per box
In re to my complete set of AC Delco tie rods... I am going to keep them for now until I confirm my Moog ones fit fine (I had the threaded end cut recently).
Howz aboot you get some pricing, let me know, then I will beat it by 1 penny, okay 2 pennies perhaps? Saves me from adding everything up again.
Old Sep 11, 2011 | 06:51 PM
  #72
Luke, my boy - you must CONCENTRATE!
Reread my front end thread, you are missing the details that make the job easy!
The control arms were pulled with the liners there. It is just a little more difficult - you do not need to pull them. If you do, BAD things will happen. You will find ugly crap that will need repainting, stripping, replacing...........
The ball joint press will work for the bushings. The adapters that are included will work, but you will need to get a few pipe fittings at the hardware store to use with the press also. Details are in my thread.
Also, my special C-clip tool thingie is nothing but a big flat washer with a notch cut in it. Specs are in my thread.
Make note which shims went where. They can be reused. Those bolts you pictured are the ones. 7/16" dia. Just replace them. They can snap without warning - I had it happen.
I put my cereal box looking gaskets on my spindles, so they are done.
My Moog sway bar bushings are different as verts and heavier and they got the 0.97" dia bar.
You and oldzy are both in canada i think - would postage be that high??
Old Sep 12, 2011 | 07:09 PM
  #73
....eread my front end thread, you are missing the details that make the job easy!
Yup, went there AFTER being 'allowed back on' last night.... Each time I read the thread I get a little more understanding. + Ihave the CSM with me in the Garage and I make frequent trips to look at it. That's not fair the way their pics show everything in pristine condition with no crud or dirt. Heck their tech models hands are even clean. Tools are spotless, tons of working room & ALL the right tools. Durned GM
Hey, you started it....and now you don't want me to take on more 'might as well' projects? Well this time you're right. I don't need to do that right now-too close to the winter season. It's bad enough stripping out of my coveralls in the garage after a sweaty workout much less stripping a frame that I'll do next year anyway.....
Bought the washers today. Might have to dremel the centers a bit though. They are .5 centers. Might have to use 2 at a time because they're not that thick.
Pics taken. When they come out I will tape them together like they came out and put them into a labled envelope. Might not affect alignment, but it will make the alignment guys job a little easier...
I'm going to buy those ones from oldzy. I could re use my old ones but they are 39 years old and you know what that means.....
Are you kidding? Postage in Canada is just as outrageous as cross border shipping.
Today I soaked all the bolts that will be coming out with penetrating oil. Doused them 2X. Holy Shamoly does that stuff stink up a garage.
Got the upper ball joint rivets drilled. Just need to get a drift to break them out. Tomorrow. Cleaned up a lot of the bolts I took out so far. Amazing how much time that consumes. But then when everything goes back together, it won't fight with me, and it will look good too!
Apparently I need a deep 9/16 socket to get that stupid shock nut at the top off. The ones at the bottom came off like they had just been put on (feel the power of the penetrating oil Luke....). Dont have any rebar to wedge into the spring so I'm going to X my fingers and just let the jack down. Right now I've got it square under the LBJ. Might need to raise the car a little before the final lowering of the CA? This stuff doesn't seem to be really hard, it just takes time to prep and plan the work.
Old Sep 12, 2011 | 07:39 PM
  #74
Some pics...
In re to my complete set of AC Delco tie rods... I am going to keep them for now until I confirm my Moog ones fit fine (I had the threaded end cut recently). Howz aboot you get some pricing, let me know, then I will beat it by 1 penny, okay 2 pennies perhaps? Saves me from adding everything up again.
How long till you know about the tie rods? It would be nice to bundle some of the stuff and clear out that space for new **** rags....
Haven't got the pricing done today. I am interested in some - not all the parts you listed. eg: I already have my upper & lower ball joints. The bushings on the control arm shaft and shaft were already pressed into place in the CAs. Will that affect them being reinstalled again? My CA shaft looks to be in good shape, but if you've already got the bushings on them...
I want to be clear about something well in advance. Just to make sure that I understand the offer you made. Whatever parts I buy from you, the total amount I will pay (no GST/PST or HST or I Keel you); including shipping to me in Edmonton, will be less than what it would cost me to drive down to my local NAPA store and buy them? It's a very lucrative offer and I just want to make sure that we both understand the same thing.
Old Sep 12, 2011 | 07:45 PM
  #75
Sounds like you got the wrong washer. One cheapo 5/8" flat does the job - center hole needs to be 0.7"...
I found it easier to chisel out the upper ball joint once the rivet bottoms are drilled. Do not expect those rivets to just popout - they are bonded to the ball joint plate up top. I hammered a lot with a drift going nowhere before I realized that...
Hope your upper shock nuts come off - my fingers are crossed. If not, those nut cracker things would work.
Old Sep 12, 2011 | 08:20 PM
  #76
K, I'll take them back and get the right one
???You drill the bottoms too? Or did you just keep drilling the center till it went all the way through the rivet? Didn't see that in the CSM or your thread??? How are the BJs bonded - rust or glue? I have metal chisels. Do you just go under the BJ and keep whacking till it separates? Only thing I saw in your thread was 'light tap with cold chisel to separate'
You and me both. They've been soaking in penetrating oil all day. If the tops are like the lowers, it should spin off nicely.
Old Sep 12, 2011 | 09:20 PM
  #77
oldzy's Avatar
HST!
HST!
HST!
HST!
yallz got it lucky over there.... or was that BC? Cannoot recall eh.
I know now... I will just use my Moogs. If too long still, will just trim the threads again.
I would likely not use those bushings (or the shafts) on that upper ctrl arm shaft pic I posted... that was mostly for craps n giggles. Also, those shafts I pictured are likely not the correct for our year, and might be originals. Mine has a nut on the ends... and the one pictured has a bolt on the end. They came with the upper control arms from G. Lever... prob off a Chevelle or something. When I got the upper control arms (I also got a nice set of original front lower arms from him as well), I took them all over to a local garage to have all the bushings/joints put in.
FYI... I have 5 rods in total (well 6 six actually... the 6th one is a defect that I have yet to mail back to Rock Auto). The ones that say 'Assembled in USA' on box... say 'Made in USA' on rods themselves, and have blue boots. Ones that say 'Made in USA' on box... say nothing on the rods (some symbols n stuff), and have black boots.
I need a price first, to know whether I can do the 'free' shipping thing.
Old Sep 13, 2011 | 05:24 AM
  #78
Drill the rivet heads out on the bottom (grease boot and stud) side as per the CSM. Then cold chisel the remains of the heads off.
The rivets seem to be pressed in the top side of the ball joint super tight - do not expect the rivets to pop out by themselves with a punch.
You can use a drift punch on all of them, BUT - be sure to support the control arm and NOT the ball joint top bracket/housing. That will need to come off, rivets and all. I used a cold chisel between the ball joint top bracket and contol arm and the wedging popped it out.
Clear as mud, eh? Pound hard enough and it should come off.
Old Sep 13, 2011 | 08:31 AM
  #79
I think you know what I did wrong now. For some inexplicable reason I didn't tweak to the fact that I was drilling the top rivets out. Well they're gone now so I'll do the bottoms. The control arms are still on the car so it might be a little awkward...but drilling the rivets from both sides should make the BJ top plate quite a bit more loose and it should easily cold chisel off. I'll let you know how it turns out later. Man I feel like such a putz!
Old Sep 13, 2011 | 11:35 AM
  #80
My parts pricing $$$$$ KA-CHING !!!!!
HST!
Oldzy, we don't need no stinkin HST. GST is bad enough without more of a money grab.
I phoned NAPA this morning and I don't think you can beat their prices.
For what I need, your price would have to be less than 90.00 including shipping and with the weight/size of the package that's just not likely so I ordered all the stuff from NAPA. I'm sure there will be others in your area who might need the parts and you can get better return without having to ship. I really appreciate your willingness to help out though
I am very interested in those rubber seals for the OEM rubber spindle backing plate gaskets. How much to you want for a set of those?
Here's how my Napa pricing breaks down.
Upper CA bushings 2 sets @ 11.22 each
Lower CA bushings rear 2 @ 22.99 each
Lower CA bushings front 2 @ 11.99
Idler arm 48.29
Center link 69.04
Tie Rod sleeves 2 @ 11.44 each
Inner tie rods 2 @ 37.69 each
Outer tie rods 2 @ 37.69 each
Tie rod sleeves 2 @ 11.44 each.
Shocks (Monroe sensa trac) 2 @ 39.77 each
Grand total (tax in) 488.43
Rob, FWIW the steering parts came to a total of 305.52 (tax in + NO Shipping) Finally found a great deal up here in Canada. I think I need those CA mount bolts/nuts. Fusick has them for 24.00/set NO ONE here has them and I don't want to wait 2 or 3 weeks for Fusicks order to get here. If I understand correctly, the spline is to hold the bolt from turning when you cinch the nut down? Why wouldn't a Gr 8 bolt and a lock nut work just as well? Not an engineer, but when a lock nut 'locks' on, it's not going to let the bolt move. Am I missing something?
