69 Olds Cutlass rear drum to disc complications.
Old Yesterday | 01:29 AM
Misfire's Avatar
I have a 69 cutlass I have put rear disc brakes on and cannot get any pedal on car, let me re say that, You can get a good pedal from pumping the brakes, leave it alone a minute and goes away, But can be pumped up, It was a kit, have also replaced the master cyl and prop valve twice, have stainless hoses, from what I can tell is the brackets on the rear must be a little off to where pushing the caliper pistons back too far, I have tried dragging the parking brakes on the lift to try to seat the rear pads in to no avail, have completely blocked rear brakes and have a great pedal, Any one ever run across this situation?
Old Yesterday | 04:52 AM
allyolds68's Avatar
What does the manufacturer say that you bought the kit from? They must have run into this before
Old Yesterday | 06:40 AM
JohnnyBs68S's Avatar
Did you use a residual pressure valve to maintain some fluid in the calipers when the pedal is released?
Rob64cutlass
Brakes/Hydraulic Systems
29
Apr 1, 2022 05:46 AM
matchek
37
Oct 28, 2021 09:38 AM
JCMC64
44
May 4, 2019 02:03 PM
olds68442
Feb 8, 2016 09:10 AM
veltboy618
Jan 7, 2009 12:03 AM
