69 442 BRAKES PULLING
I may have misread the original post. Is this only when brakes are applied or is it a constant thing?
If only on brake application, it's a brake-related issue. If all the time, it's suspension or front end alignment.
Ok, I've had problems with calipers where the seal would wear a groove in the piston and cause it to hang up. I replaced the pistons during a caliper rebuild and the pulling stopped. Also, check your caliper mounting hardware. Again, I usually replace the pins and o-rings when I do the pads. Finally, how old are the rubber hoses to the calipers? The inner seal can deteriorate and act as a one-way valve that prevents the caliper from fully releasing.
