69 442 BRAKES PULLING
Old May 26, 2008 | 06:35 PM
IDAS 69's Avatar
Question 69 442 BRAKES PULLING
HI,
MY 69 442 W/POWER ASSIST BRAKES ARE PULLING TO THE LEFT.... WHAT CAUSES THIS?
THANKS, IDAS 69
Old May 27, 2008 | 06:43 AM
rocketraider's Avatar
Oldsdruid
Either the left brake is adjusted too tight, or the right brake wheel cylinder is frozen and brake on that side is not working.
Old May 27, 2008 | 04:34 PM
Originally Posted by IDAS 69
HI,
THANKS, IDAS 69
Drums or disks?
Old May 31, 2008 | 06:06 PM
IDAS 69's Avatar
POWER ASSIST... IT HAS BEEN DOING BETTER SINCE NEW SHOCKS..BUT STILL PULLS LEFT.
Old May 31, 2008 | 07:09 PM
Oldsdruid
I may have misread the original post. Is this only when brakes are applied or is it a constant thing?
If only on brake application, it's a brake-related issue. If all the time, it's suspension or front end alignment.
Old Jun 1, 2008 | 09:14 AM
Sorry if I missed it, but I don't see where you've told us if it's drums or disks. It's difficult to help by long distance without all the info.
Old Jun 2, 2008 | 01:20 PM
IDAS 69's Avatar
Sorry. disc
Old Jun 2, 2008 | 05:30 PM
Ok, I've had problems with calipers where the seal would wear a groove in the piston and cause it to hang up. I replaced the pistons during a caliper rebuild and the pulling stopped. Also, check your caliper mounting hardware. Again, I usually replace the pins and o-rings when I do the pads. Finally, how old are the rubber hoses to the calipers? The inner seal can deteriorate and act as a one-way valve that prevents the caliper from fully releasing.
Old Jun 3, 2008 | 12:40 PM
IDAS 69's Avatar
Thanks Joe, I'll check all these items out. Thanks your a lifesaver.
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
442craig
Apr 10, 2012 12:22 PM
russell-t
Apr 30, 2011 05:56 AM
IDAS 69
Jun 10, 2009 02:36 AM
