68 cutlass front disk conversion
Old Dec 17, 2015 | 05:58 PM
servexcell's Avatar
I am doing a frame off on a 68 cutlass. I have purchased Disk spindles with backing plates and caliper brackets.
The car originally had no power brakes. If change to power brakes I will need a booster but can I use the same MC and can I use the existing distribution block.
thanks Bruce
Old Jan 1, 2016 | 05:22 AM
lvnfld's Avatar
bruce
I am doing the same on my 69 delta, I am sure you will have to get a new mc and power boost to hook up to your vacume on engine.
I bought the whole kits from ssbc.com and you will need a proportioning valve for the rear brakes
cheers
terry
Old Jan 1, 2016 | 06:58 AM
thanks Bruce
The same MC as what? The drum brakes? Drum and disk M/Cs are completely different. Also, power and manual brake M/Cs usually (but not always) have a different bore diameter and are thus also different.
Note that if you do convert to power brakes, DO NOT throw away the pushrod, retainer, and boot from the manual brake M/C. These parts are unique to manual brake cars and are sought after.
delmontcrusier
May 28, 2023 07:37 AM
davoaz
Brakes/Hydraulic Systems
Feb 25, 2016 03:03 PM
Larrys'66
Apr 18, 2014 06:11 PM
Troys Toy 70
Jun 7, 2012 04:29 PM
brownron1
Aug 29, 2008 05:02 AM
