68 4 wheel drum issues
Old Jul 14, 2022 | 09:37 AM
Kevin W's Avatar
I’m having an issue with the brakes for my 68 442. I can’t seem to get a firm pedal and all the air out of the system. This is a frame off restoration, 4 wheel drum car, everything is new (new brake lines, hoses, wheel cylinders, shoes, hardware and master cylinder).
First thing, I bench bleed the master cylinder, I did noticed that the rear port (rear line) doesn’t seem like I can remove 100% of the bubbles (I’m using the clear vinyl tubes routed back into the master cylinder reservoir), I can see very fine air bubbles in the tube. Front port looks great. After I vacuum bleed the system, using a liberal amount of fluid until I see no more air bubbles, I have spongy pedal (even after pumping the brakes) Go back and vacuum bleed and I find more air. So I try the old proven method of having the wife in the car, push in the pedal while I open and close the bleed screw. After going thru 20oz of fluid for the right rear, I’m unable to remove all the air, I’ll get like 4 pumps without air then back to fine air bubbles and then it will clear and then back to air. So I have to assume at this point, somehow I’m sucking air into the system. I have look at the entire system and don’t see any leaks or weeping from anywhere on the system. My first assumption was a bad master cylinder, the problem with that, this is my 2nd master cylinder with the same results. At this point, I have no idea how to trouble shoot this? Is it possible for a master cylinder or wheel cylinder to allow air into the system without leaking fluid?
Old Jul 14, 2022 | 09:51 AM
How I bleed the brakes with the use of a warm bodied helper after adjusting all four brake shoes for light contact against the drums.
1 Have the helper pump the brakes until the pedal is firm and hold light steady pressure.
2 I open the bleeder at the RR wheel cylinder which in turn the helper pushes the brake pedal gently to the floor and holds it there.
3 Close the bleeder.
4 Repeat until there is no noticeable bubbles and getting a steady stream of fluid from the bleeder.
5 Periodically check fluid level to ensure the bowls don't empty.
6 Perform the same exercise on the remaining wheels.
Note, the helper needs to hold the pedal to the floor until the bleeder is closed, letting it come back up with the bleeder open allows air back into the system.
Old Jul 14, 2022 | 10:29 AM
Kevin W's Avatar
Thank you for the reply. This is the same process that I have used, minus the pedal never gets firm, which would indicate bad MC.
TheBigBlueBoat
Brakes/Hydraulic Systems
Jan 13, 2016 06:02 AM
young olds
16
Oct 27, 2015 08:10 PM
1973nomega
20
Jul 24, 2014 08:14 AM
rket56
Nov 30, 2013 03:45 PM
54olds
Oct 31, 2007 07:24 PM
