Correctly Reinstalling Master Cylinder Cover on 72 Cutlass
Old Jul 17, 2022 | 09:44 AM
cutlass47's Avatar
After brake light on instrument panel stayed on, I checked fluid level in master cylinder on my ‘72 cutlass (disc/drum brakes) and front was full but rear of MC was almost empty. I filled the rear almost to top. Now I am not sure proper way to reinstall MC cover. I assume you depress the bellows of the diaphragm on the cover first and make sure cover is secured by the metal latch. Can I pull the car into the garage to get it out of the hot sun before reinstalling the cover?Also, the cover has been removed for a couple of hours now while I have been searching for solutions to my low brake fluid problem. Will I have to have the brakes bled now that I have added fluid?
Old Jul 17, 2022 | 09:58 AM
sysmg's Avatar
You should never leave it open especially if it's really humid outside. Brake fluid absorbs water. Yes, you depress the bellows and clip it on. I would put it on before moving the car, you don't want debris from the hood insulation getting into the MC.
There must be a reason the rear was empty. It could be a bad master and brake booster where the fluid was sucked into the engine. Or it could be a leak at either of the rear brake cylinders, the rubber brake host above the rear axle, or a small leak in one of the metal lines going to the rear or to the rear brake cylinders.
Based on your questions, I would hire a professional to take care of your brakes. The consequences of brake failure are serious enough that you shouldn't be working on them if you don't have any expertise.
richeyb
Brakes/Hydraulic Systems
Mar 26, 2018 12:12 PM
rcdynamic88
Aug 14, 2014 06:00 PM
jensenracing77
Mar 28, 2014 12:35 PM
veltboy618
Jul 14, 2011 07:10 PM
Cecil Anderson
Jun 4, 2010 09:35 AM
