67 CS Brake Distribution Block Wire
Old Feb 15, 2019 | 10:49 AM
babailey's Avatar
I am rewiring a 1967 Cutlass Supreme Holiday Coupe. I’m using a painless wiring harness. I just found that my power brake distribution block has an electrical connection. Where should that wire be connected? I’m hoping it is just to the brake dummy light on the dash (unfortunately, the new wiring harness does not contain this wire).
Reading the chassis manual, page 5-22, it sounds like the wire should be part of the park brake circuit. However, that was not wired when I got the car so I don’t know what wires should go where.
Any help would be appreciated. Thanks,
Old Feb 15, 2019 | 07:23 PM
Yes, it supplies a ground to the parking brake lamp on the dash. It lights the lamp if the little shuttle valve (differential pressure switch) inside the block shifts one way or the other due to loss of fluid in either compartment of the master cylinder.
BackInTheGame
Jul 12, 2016 07:22 AM
Octania
Nov 6, 2015 06:37 PM
tommyd
May 14, 2014 08:19 PM
442_Mustang
May 10, 2010 05:18 AM
nelsontj
Sep 19, 2009 04:24 PM
