63 Dynamic 88 Brake Booster Rod Setting Issue
Old Apr 20, 2017 | 03:38 AM
slw0501's Avatar
We had the original booster rebuilt but when installed on the car the brake peddle locks up. Requires removing master cylinder to relieve vacuum and release the peddle. We have adjusted the rod by measuring the distance from the master cylinder seat to bore face, bore face to housing surface. Results in booster rod length of 1.125" which should not place any preload on the master cylinder. Had to isolate (unhook) the reserve vacuum tank due to a leak. Have installed a Chevrolet booster with a much different rod length that works but it's not original. Suggestions please...
So after posting this I discussed with a mechanic who advised that even though I am setting the rod to the derived measurement, I am still probably pre-loading the MC due to improper pedal adjustment. I will give this a try and update this post accordingly.
Still seeking input from forum members.
rebuilt brake booster
Camaro booster
firewall side of Camaro booster in back, rebuilt Olds (Morraine) front left
Camaro booster (note rod is very short)
Master cylinder (bought new from NAPA)
jetstar88mike
Brakes/Hydraulic Systems
Aug 3, 2015 09:27 AM
defiant1
Mar 22, 2015 07:05 PM
67 Cutlass Freak
May 13, 2014 05:26 PM
W-27
Dec 10, 2013 10:25 AM
defiant1
Mar 30, 2011 06:30 AM
