4 wheel disc brake feedback wanted
Old Sep 18, 2015 | 06:27 AM
rktolds's Avatar
I'm starting a resto on a 72 U code big block Cutlass Wagon this winter. I can't decide if I want to put discs on the back, leave it drums or upgrade to vista drums.
Who has 4 wheel discs and drives their car a few thousand miles a year? Was it worth it? I plan on only driving state highways but I want to be able to hit the interstate and feel safe.
I'm leaning towards disc/disc since it already has discs in the front. I am rebuilding the system so I want to know if the extra$$ is worth it. Thanks.
Matt
Old Sep 18, 2015 | 06:32 AM
rktolds's Avatar
Who is running 4 wheel discs?
Posted in brake forum too. I would like feedback from people who drive their car a few thousand miles a year and have done the conversion. Was it worth the $$? The car in question is a 72 U code BBO Cutlass wagon disc brake car. Thanks.
Matt
Old Sep 18, 2015 | 06:40 AM
1968_Post's Avatar
4wheel DB
I built a 67 Nova SS BBC car and installed a Dana 60 with disc brakes. Somewhere along the line it became necessary to change the differential to a Ford 9 inch that was built with 11 inch drums. To be honest, I couldn't denote any appreciable difference in stopping power. That said, the car only weighed 3000 lbs soaking wet, which is probably a lot less than what you're building. I do know the drum setup was a whole bunch less expensive...
Old Sep 18, 2015 | 07:01 AM
I merged your two identical posts because you will almost always get a better answer if you keep all responses in a single thread.
Old Sep 18, 2015 | 07:15 AM
rktolds's Avatar
Thanks Joe.
I bet the wagon weighs close to 4000 lbs so she's not a light weight! Thanks for your response.
Old Sep 18, 2015 | 09:07 AM
RonFX's Avatar
Hello:
I upgraded the brakes on my 66 Cutlass to disc on the front and 11" drums on the rear. I bought a complete front kit from a supplier. The rear upgrade backing plates came from Packrat, they were off a 77 Cutlass. It was one of the easiest jobs I have done to the car. Even with buying backing plates and all new drums / hardware, I was still under the rear disc kit. The car is a long term project, so I have not driven it yet, but I expect everything will be fine.
Thanks, Ron
Mocephus
Oct 1, 2021 09:45 AM
mid60soldsfan
Mar 13, 2014 08:39 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
jon69olds
Wheels and Tires
Feb 11, 2011 11:57 AM
jasoneswan
Nov 22, 2008 06:41 AM
