3/16 VS 1/4 brake lines?
Old Feb 4, 2024 | 11:45 AM
eggydrummer's Avatar
My 61 Olds 98 has original 3/16 brake lines, I used a caliper to measure. There is a long, rusty run, along the frame, going to the rear, which splits in two, going to either brake cylinder.
My question is, do I splice in a new chunk of 3/16 wherever needed, or do I replace the entire run? Do I keep 3/16 or increase to 1/4?
Thanks for the input friends,
Old Feb 4, 2024 | 12:06 PM
BackInTheGame's Avatar
My $.02 - Replace it all at once, using the same size(s).
Old Feb 4, 2024 | 02:21 PM
The diameter of the line doesn't matter. Brake systems don't flow a lot of fluid once the air is bled out. Is there a reason why you think the engineers who originally specified 3/16" were wrong? And yes, replace the whole line.
Old Feb 4, 2024 | 03:22 PM
I didn’t know for sure about the diameter. Keep it as is I will do.
Thanks for the feedback Joe.
eggydrummer
Jan 17, 2024 06:59 AM
highschoololds
Brakes/Hydraulic Systems
Feb 7, 2020 05:05 PM
rr69ho
Jul 25, 2019 04:23 AM
TomT
Mar 24, 2018 03:00 PM
cskucinsky
Jul 20, 2015 05:11 PM
