1972 cutlass drum brake convert to disk need help
![Smile](https://classicoldsmobile.com/forums/images/icons/icon7.gif)
Hello I have a 1972 cutlass with drum brakes in the front. I also have the 15 inch rallye wheels on it. I found a 74 cutlass in the junk yard and I took the full disk brake setup off the 74. The spindle and hub, rotor and caliber also brake line. Will the 74 fit on my 72?
The only way to make this work is to modify your control arms to use the correct ball joints for the 74, but even then the steering arms, which are part of the one-piece spindle in 1974, will be in the wrong place, causing bump steer. Get rid of these spindles and get the correct 1964-72 parts.
This really sucks. I been told bu other people that it will work. Well thanks for the info. I had everything sand blasted and painted. Hopefully I can get my 100 bucks if I sale this setup. Thanks.
This question comes up a lot and I always say that a little common sense needs to be applied. If this inexpensive late model spindle swap worked, the aftermarket disc brake kits for the 64-72 cars would be priced a whole lot lower than they are. In any case, if it helps with your sale, these spindles fit all 1973-77 A-body cars (Cutlass, Chevelle, etc), 1970-81 F-body (Camaro/Firebird), and 1975-79 X-body cars (Nova, Omega, etc). Unfortunately, every one of those cars came with front discs from the factory, so there's not a lot of demand for these parts.
Actually I did ask questions even the guy at the junkyard told me it would work. Any oldsmobiles from 67-87 that end up in the junkyard, are strip from its parts fast the damand for them parts are very high.
Of course, I'm sure there's a no returns policy, even it THEY are the ones who make the mistake.
![Roll Eyes (Sarcastic)](https://classicoldsmobile.com/forums/images/smilies/rolleyes.gif)
delmontcrusier
May 28th, 2023 07:37 AM
brown7373
Brakes/Hydraulic Systems
March 16th, 2014 06:31 AM
perro
September 3rd, 2007 01:30 PM
