1969 Olds 442 Master Cylinder
Old Jan 11, 2023 | 05:57 PM
I-ROK's Avatar
I am trying to put any basket case of a 1969 Old 442 back together but do not have a master cylinder or brake booster. The car has front disk and rear drums. Can anyone advise the proper size of booster i should be using.
Old Jan 12, 2023 | 06:22 AM
The stock booster is 11". Correct replacement A-body boosters and master cylinders pretty much grow on trees, since Chevelle is the same. Be aware that if this is a FACTORY disc brake car (as opposed to a conversion), it does not use a proportioning valve or combination valve. Olds carefully selected the size of the rear wheel cylinders to achieve the required front/rear brake balance without a prop valve. There should be a metering valve under the master cylinder. This is NOT a proportioning valve and performs a completely different function.
joshduty
Brakes/Hydraulic Systems
Mar 22, 2022 07:15 PM
troyd
Dec 8, 2021 05:59 PM
arcee1951
Mar 1, 2016 06:05 AM
rspreen1
Jul 4, 2015 01:13 PM
STLCRZY
Mar 10, 2014 07:36 AM
