drum to disc on '63 Olds Super 88
Old Jan 11, 2023 | 08:31 AM
63OLDSSUPER88's Avatar
Good morning
New owner of a beautiful 4 door '63 Olds Super 88. I bought this car with air ride and 20s already on it. I'm in the process of cleaning up the previous owners mistakes and ugliness. I am curious if anyone has ever done a drum to disc conversion on these kind of cars? Thanks in advance.
Old Jan 11, 2023 | 10:10 AM
rocketraider's Avatar
Oldsdruid
Not sure what's available for the fronts now, at one time you had to send in a set of spindles for machining to adapt discs to them.
Scarebird has had a disc kit available for the 57-64 Olds and Pontiac rear axles for many years.
Old Jan 12, 2023 | 06:15 AM
67OAI's Avatar
Old(s)GuysRule
Contact Charlie Jones. Charlie has a build thread in the "Major Builds and Projects" section of this site and has the info you are looking for!
Old June 18th, 2020, 10:54 PM
#191
Charlie Jones
Phantom Phixer
Charlie Jones's Avatar
Next the brake discs and calipers were installed in front . Discs were checked for run-out ;
Scarebird brackets and hubs , '72 Cutlass calipers , and '76 Ford T-Bird rear rotors .
__________________
I choose to restore an Oldsmobile . Not because it is easy . But because it is hard .
Darksider #1 Last edited by Charlie Jones; June 18th, 2020 at 11:07 PM.
Charlie Jones is offline Report Post
Quote Multi Quote Quick Reply
Old Jan 12, 2023 | 07:27 PM
Tedd Thompson's Avatar
Try thishttp://discbrakemike.com/, he has been doing conversion for years... Tedd
Old Jan 12, 2023 | 07:50 PM
Most kits for this conversion will leave you wishing that you'd just done a good overhaul on the drum system.
Old Jan 12, 2023 | 09:39 PM
griffey57's Avatar
That's what I would do is go through the drum brakes completely and they do work very well.
Old Jan 13, 2023 | 07:17 AM
Phantom Phixer
Scarebird is going out of business, and doesn't list a kit for 63 thru 68 Olds anymore.
Scarebird Classic Brakes LLC
Old Jan 13, 2023 | 08:14 AM
Besides, the name "Scarebird" doesn't inspire a lot of confidence in their product.
markmag
Dec 7, 2019 05:09 AM
oldzkool
Brakes/Hydraulic Systems
Nov 11, 2014 07:51 PM
Warhead
Feb 20, 2011 10:06 AM
