1968 Olds 98 drum brakes
Old Jun 5, 2009 | 02:20 PM
phil7395's Avatar
I am having my front drums turned and I was wondering why the drivers side physically is different than the passenger side drum. The Driver drum has a large flange on it, where as the passenger side is a normal looking drum. Thanks for any information. Phil
Old Jun 5, 2009 | 03:28 PM
One of the two drums has been replaced at some time in the car's life.
Old Jun 5, 2009 | 04:11 PM
rocketraider's Avatar
Oldsdruid
There were two different drums used on the 65-70 big cars- one with the large flange and no fins, the other without flange and with cooling fins. As Joe says, one has probably been replaced.
Old Jun 5, 2009 | 08:28 PM
phil7395's Avatar
Brake Drums
Do you think having different drums will create any problems? I am dealing with a front end issue that occurs around 35 mph. I have replaced wheels and tires and still the problem remains. I have had the front end checked and I was told that everything was good. Any ideas? I know I am probably not giving you all the information you you like to hear, but that is what I know as of right now. Thanks again for taking the time to answer my questions.
Old Jun 6, 2009 | 03:56 AM
Yellowstatue's Avatar
Smile Deviate
While you are wandering around in the wreckers you could be looking for a set of disc brakes for your '98...solves your brake drum problem...
Old Jun 6, 2009 | 10:51 AM
Yeah, then you just need to find a source for 67-70 B-body rotors...
matviar
Oct 22, 2014 11:12 PM
455Olds
Brakes/Hydraulic Systems
Dec 8, 2013 08:16 PM
Oldssupreme
Jan 29, 2013 07:03 PM
1carsick
23
Oct 2, 2012 05:50 PM
phil7395
Jan 1, 2012 06:19 AM
