1967 brake proportioning valve
Old May 31, 2025 | 02:53 PM
Bkab_jay's Avatar
I’ve got this project car, that as I dig into it o keep finding stuff that just doesn’t belong on the car.
so this proportioning valve was on the inside of the frame in the way of my headers and I moved it out.
Redoing all brake lines, leaving it drum and drum.
The front line I let looks weird. My pops thinks it’s smashed, it looks very uniform to me like it was made like that. Since we disagree, heck with it, let’s order a new one.
but I don’t know what I need. Anyone have a part number for the correct one? I know Jack all about these things.
2nd pic is the area I’m talking about.
Old May 31, 2025 | 06:50 PM
This is for an A-Body, right? I think ILT (Inline Tube) sells exact replica...
InLine Tube >>> https://www.inlinetube.com/products/pr106
Amazon >>>
Amazon Amazon
Old Jun 1, 2025 | 04:52 AM
Once again, that is NOT a "proportioning valve". There are no "valve" components inside of it. It is simply a distribution block with a center piston that operates the differential pressure switch that turns on the BRAKE lamp if you lose pressure in one half of the system.
Old Jun 5, 2025 | 04:19 PM
Bkab_jay's Avatar
Amazon >>> https://www.amazon.com/Inline-Tube-D...rReviewsAnchor
Thank you!
Old Jun 5, 2025 | 04:20 PM
Bkab_jay's Avatar
Thank you for the clarification. Everything I’ve seen for sale says proportioning valve.
Old Jun 5, 2025 | 06:18 PM
Most vendors, including the ones who specialize in disc brake conversions, get a lot of this incorrect. This is why I'm down on most aftermarket kits.
Old Jun 5, 2025 | 06:20 PM
Apparently ILT has cleaned up their act. The correctly call this a distribution block, and they also correctly call the 67-70 metering valve a "hold-off valve". Previously they had incorrectly called it a proportioning valve.
Old Jun 5, 2025 | 06:56 PM
Serendipitously, I've noticed same over some time.
Old Jun 5, 2025 | 07:03 PM
Old Dec 25, 2025 | 12:16 PM
Rpiper's Avatar
Angry 67 distribution or proportional? Hold off?
So I am changing out the front discs(pretty sure aftermarket), the line from the front LH side to the distribution block broke. So I ordered a new SS set from Inline, and they sent out a hold-off and a distribution block. I have a few questions: 1. Do I need both of these? 2. Where does the distribution valve originally go, because right now it is mounted between the frame and inner fender wall, making it very difficult to access.
Old Dec 25, 2025 | 12:36 PM
The metering valve and distribution block were used for factory disc brake installations in 1967. If your car was converted (which is likely) then you do NOT want these parts and instead want a combination valve. Factory disc brakes would have used four piston fixed calipers. If your car has the more common single piston floating D52 calipers, it has been converted. Use a combo valve.
Minnesotajeff
Dec 18, 2024 02:48 PM
JesseOldsGuy
Brakes/Hydraulic Systems
Jan 24, 2024 07:01 AM
matt69olds
Jan 24, 2023 03:52 PM
Rallye469
May 12, 2022 12:02 AM
ScottMHoffman
Sep 16, 2016 11:13 AM
