1962 Olds Dynamic 88 Brake Booster
Old Aug 7, 2014 | 07:53 AM
mondi1962's Avatar
Question 1962 Olds Dynamic 88 Brake Booster
I was trying to change out my leaking master cylinder Cast #5460982 with one I already have but which I thought it was a bendix because it is black and only has 2 Bolts holding the master on. After removing the cylinder, the piston was stuck on the booster and I ruined it trying to get it off. I am thinking I may have a moraine setup since the booster has no bolts holding it together. The new replacement master I have with the same casting #5460982 has the piston inside held with a sir-clip. That's why I thought it must come off. Honestly I am still not sure. Can you please take a look at the attached pictures.
Old Aug 7, 2014 | 09:11 AM
D. Yaros's Avatar
Am going through the same repair right now myself. Your booster most certainly is a Delco-Moraine single diaphragm unit.
Color means nothing. If the booster halves are held together with 8 bolts it is a Bendix. If the halves are joined via tabs/slots it is a Moraine.
There are rebuilders out there for the unit. Booster Dewey is one, but he is closed for the month of August.
Brake Materials & Parts is another.
Old Aug 7, 2014 | 09:29 AM
mondi1962's Avatar
Question Piston
So is your piston attached to the booster like mine?
The replacement master I bought has the piston inside it.
Old Aug 7, 2014 | 09:36 AM
mondi1962's Avatar
Here's a Picture of the replacement master.
Worst part is the brakes were working when a took it apart.
Old Aug 7, 2014 | 10:36 AM
D. Yaros's Avatar
The replacement MC looks nothing like mine. The repair manual has a schematic of the Moraine MC. The Moraine booster piston does indeed rest on the MC Check Valve/Spring/Primary Cup assembly.
Here is the thread I started on this, which taught me a bit about the booster unit.
Brake Fluid Gone?
Old Aug 7, 2014 | 11:57 AM
mondi1962's Avatar
Brake Fluid Gone?
I know every one i find looks like yours with the 4 Bolt master. Its like I have a cross between a bendix and a moraine.
Do you know how to get the piston off the booster on the moraine?
Old Aug 8, 2014 | 08:31 AM
D. Yaros's Avatar
Instead of trying to get the replacement part to work, why not just rebuild the MC that did in fact work at one time?
The folks at Brake Materials & Parts (link provided above) considers the MC and booster to be one unit and will rebuild it for you.
Old Nov 18, 2015 | 01:47 PM
mondi1962's Avatar
I have not been on here since I fixed it. So here's an update.I ended up buying a new piston for my booster since it was like new when I took it apart. Then I used the new master I bought by removing the piston and it worked. I figured they were the same since they had the same casting numbers. Just set up different depending on which booster it went on.
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
67 Cutlass Freak
May 13, 2014 05:26 PM
eodette
Oct 12, 2010 07:26 PM
eddieunderground
Sep 2, 2010 08:26 PM
skaboy 40
Apr 12, 2007 08:22 AM
