1940 olds series 90 rear rubber line
Old Jul 3, 2022 | 02:50 PM
potopa's Avatar
Does anyone have a part number or lead on the rear rubber line for a 1940 series 90? I was under it today taking care of the gas tank and notice mine is weeping.
Thank you
Old Jul 3, 2022 | 07:42 PM
Charlie Jones's Avatar
Phantom Phixer
Can you further explain which rubber line you need?
Is it for the fuel system, or the brakes?
Old Jul 5, 2022 | 06:28 AM
potopa's Avatar
the soft line for the brake. I saw one that is a straight run but i think the one i have has the t built in to go to the hard lines. I need to clean things up to get a better look, i may be wrong.
Old Jul 5, 2022 | 07:17 AM
Phantom Phixer
The brass "Tee" is a separate part.
The factory part number for the hose is 408787 and is used on all 37 thru 40 Oldsmobiles.
Old Jul 5, 2022 | 07:38 AM
Phantom Phixer
I found this one at Fusick;
https://www.fusickautomotiveproducts...sp?number=6560
firstoldsmobile
Oct 21, 2021 04:07 AM
NTXOlds
Jun 24, 2021 07:54 AM
jimvbills
Sep 17, 2019 09:05 AM
Luch
Ninety-Eight
Oct 30, 2015 10:36 AM
65 starfire
Brakes/Hydraulic Systems
Feb 11, 2008 11:31 AM
