bolt sizes
Old Nov 1, 2013 | 03:24 PM
denf221's Avatar
bolt sizes
I took the metal piece off the top of the radiator in order to paint it and I have lost the bolts, does anyone know what size they are? this is the metal piece that bolts to the top of the radiator about 2 feet long. under the top part that attaches to the car there is 7 washers used as spacers on each side, somebody help.
Old Nov 1, 2013 | 04:00 PM
I'm assuming this is on your 72 Cutlass. If you have the other bolt slide the threaded end into an open end wrench, 5/16, 3/8, etc... Which ever it fits snugly is the diameter, then measure the length from the bottom of the head to the end, then determine if its fine or course thread (pitch). Bolt sizes are based on diameter-pitch x length.
So of the bolt slides into a 5/16 wrench and is 1 inch long and it's course thread then it is a 5/16-18 x 1 bolt.
I believe those are supposed to be flange bolts flange bolts and the 7 washers on each side sounds like it has been modified in some fashion.
Old Nov 1, 2013 | 05:42 PM
denf221's Avatar
bolt sizes
nope I don't have any of the bolts.
Old Nov 1, 2013 | 07:39 PM
Do you have a bolt that will screw into the nut plate under the top cover. Then you can measure that.
Old Nov 1, 2013 | 07:49 PM
The bolts that hold the radiator top plate are 5/16" (shaft) x 18 (thread/inch) x 3/4"(length). The bolt head size is 1/2"
Old Nov 1, 2013 | 08:01 PM
Are they flange bolts Allan like the 67?
Old Nov 1, 2013 | 08:05 PM
I don't have a 67 to reference them too Eric... but I do have a 72 Cutlass S.... I would say yes, but without the locking feature on the bottom of the flange.
Old Nov 2, 2013 | 11:17 PM
denf221's Avatar
thanks a lot now on mine like I said the top two bolts had 7 washers under each bolt, is your car like this? how long would you say these bolts are?
Old Nov 3, 2013 | 04:25 AM
These are on Allans car, 5/16-18x3/4 Flange Bolt. I will add that nowhere did the factory place 7 washers under any bolt.
Old Nov 3, 2013 | 05:13 AM
Octania's Avatar
http://www.auveco.com/product/body.html
"hex washer head"
typically pointy and threaded all the way to the end.
Auveco sells new items
many of us have 100's of used ones if that would suit your needs.
atkinsom
Jan 24, 2021 10:25 AM
foo
Dec 5, 2012 08:18 AM
delta88_frankfurt
Nov 3, 2012 03:06 PM
delta88_frankfurt
Sep 10, 2012 09:59 AM
DAN76
Mar 19, 2009 04:21 AM
