Blast Cabinet Media...Help
Old March 1st, 2011, 08:07 AM
1970 Cutlass Convertible
frasco's Avatar
What type of media should I use to remove paint and surface rust on small parts in a blast cabinet?
--Scott
frasco is offline
Old March 1st, 2011, 09:34 AM
Eddie Hansen's Avatar
what kind of parts?
and what type of finish do you want, I use glass beads in my small cabinet, but I also have some aluminum oxide which can be very agressive, and you can always use play sand! if it is electrical like a starter armature or something you want to get a tumbler and use walnut shells etc.
sand and glass beads gets duller as you use it, aluminum oxide gets sharper, be sure to wear a dust mask even though you are using a cabinet, silica in your lungs is very unhealthy.
Eddie Hansen is offline
Old March 1st, 2011, 06:52 PM
Steve Wike's Avatar
Frasco:
A buddy of mine let me use his blasting cabinet, with alum. oxide. It cleans really good and even "smooths" out areas that are really bad. I did the original wheels and they came out great.
PS: Did that young man outside of St. Louis ever get rid of the Cutlass you got the doors from?? Just curious.... Take care!
Steve Wike is offline
Old March 1st, 2011, 06:57 PM
frasco's Avatar
Info
I have been trying to get in touch with him. What parts are you looking for?
Scott
frasco is offline
Old March 2nd, 2011, 11:38 AM
trackz man's Avatar
My son and I recently purchased a Blasting Cabinet from HF. There were acouple of things that we had to do to bring it up to our working standards- Just read the reviews at HF.com, before buying.
We used aluminim oxide on a bunch of parts that we are using underhood. It really blasts off the rust and debris very well- Just make sure and do not get to much dirt/rocks/wood in your cabinet otherwise the gun will get plugged-We have done that a couple of times already...We use walnut shells on aluminum parts and and paint removal only- Have not tried glass beads yet.
Good buy at HF $175
trackz man is offline
nonhog
June 12th, 2022 11:01 AM
red130
September 27th, 2012 08:16 AM
Jeff70442
January 16th, 2012 09:41 PM
dynamic88
November 3rd, 2007 08:12 AM
Quick Reply: Blast Cabinet Media...Help
