72 cutlass lower cowl HELP
Old Apr 22, 2020 | 06:32 PM
72cutlass91's Avatar
72cutlass
Hello I have a 72 cutlass supreme. Behind the front fenders that the lower fender bolts to? I cant seem to find a nice picture of what its suppose to look like behind the front fenders on the cutlass. Mine is rotten and and I want to cut it out and replace it but cant find a good picture for comparison. The torque box is in ok shape just the rest of it by the bottom cowl and fender bracket is gone. Any help thank you.
Old Apr 23, 2020 | 06:17 AM
RetroRanger's Avatar
72 Olds CS
I think coppercutlass posted a pic of that area you might try searching his posts
Old Apr 23, 2020 | 02:00 PM
72cutlass
thank you very much I will.
Old Apr 23, 2020 | 05:36 PM
Eddie Hansen's Avatar
hope this helps
https://www.ebay.com/itm/For-1968-19...75.c100623.m-1
hope this helps bud
Old Apr 23, 2020 | 06:04 PM
scrappie's Avatar
A little rusty but maybe what you need?
Old Apr 23, 2020 | 06:40 PM
72cutlass
this is exactly what I needed thank you very much wow what a difference mine is rusted to s$%#!
Old Apr 23, 2020 | 06:41 PM
72cutlass
Do you have any more picture angles?
Old Apr 23, 2020 | 06:46 PM
2blu442's Avatar
This is a common problem area. I'm sure there's several members here who have replacement metal on their parts cars, including me. If you want to go that route I'd encourage you to create a parts wanted thread.
John
Old Apr 23, 2020 | 06:47 PM
72cutlass
Originally Posted by Eddie Hansen
thank you it does help alot. My lower bottom piece of that of that is toast....
Old Apr 23, 2020 | 06:49 PM
72cutlass
John
I just want to see some pictures first to see if I can fab it myself. I just had no good picture to go by. If it ends up me going to the wanted ads then it shall be done. Thank you
Old Apr 30, 2020 | 07:47 PM
72cutlass
https://www.ebay.ca/itm/Firewall-Low...odel%3ACutlass Supreme%7CTrim%3ABase%7CSubmodel%3ABase%7CEngine%3 A5.7L 350Cu. In. V8 GAS OHV Naturally Aspirated%7CEngine - Liter_Display%3A5.7L&_nkw=1972+chevelle+frame+box
does anyone know if these will fit on a 72 cutlass ?
Old May 1, 2020 | 05:06 PM
Schne442's Avatar
No it's not a parts car!!
Yes they will
I installed one on my Drivers side when I replaced the floor pan section
Old May 1, 2020 | 06:52 PM
72cutlass
Originally Posted by Schne442
Yes they will
thank you
Old May 22, 2020 | 03:16 PM
kencpless@gmail.com's Avatar
The correct j-nut that is the attaching point for the lower fender bolt is very difficult to find. It's still attached to the blue car pictured in this thread. The new ones available that are listed and described as "correct" are not close to the original.
Old May 22, 2020 | 03:24 PM
Here's my car before paint. Maybe you can zoom-in on the lower cowl area and they'll help.
Old May 23, 2020 | 06:41 PM
72cutlass
perfect thank you i found everything i needed from you guys. Thanks again!
Bfg
Jun 16, 2018 07:51 AM
bill curnick
Jan 4, 2018 03:44 PM
Bills72
Nov 13, 2012 08:37 PM
72cutlassdog
Jul 25, 2012 09:00 PM
Alex72cutty
Feb 7, 2012 07:32 PM
