72 cutlass fenders
Old Jul 25, 2012 | 06:18 PM
72cutlassdog's Avatar
72 cutlass fenders
I was told that a 4 door cutlass front fenders are the same as a coupe? I thought I get some opinions about this further. Thanks for the help.
Old Jul 25, 2012 | 06:47 PM
jensenracing77's Avatar
they are the same other than a holes punched for differant trim or emblems.
Old Jul 25, 2012 | 07:36 PM
What Eric said ^^. If you're going to aftermarket? Watch what you buy - some of them fit very poorly.
Eric is one of our highly valued resident parts distributors. If you need a whole new fender he will be able to help you or point you in the direction of someone else who has the fender.
Just an FYI, if the fender you have is good except for the lower portion behind the wheel? You can cut that out and repair it with a patch panel. Might have to remove the rear fender brace to do it right, but the fit of OEM is superior in every way.
Old Jul 25, 2012 | 08:17 PM
There off a 72 and have all the trim along with cutlass emblems already on it. all I have to do is prime and paint.
Old Jul 25, 2012 | 09:00 PM
Slam dunk. I'd pull the emblems and paint the fender while they're off. Easier to re-attach. Good luck!
jensenracing77
Dec 2, 2011 09:33 PM
6inarow
Dec 8, 2010 06:59 AM
donnief6
Jan 18, 2008 10:18 AM
dholmes898
Feb 28, 2007 06:47 PM
72drptop
Jul 5, 2006 10:54 AM
