Aftermarket w 25 all glass lightweight springs
Old February 10th, 2018, 12:01 PM
olds3442's Avatar
Anybody have luck with lightweight springs
On all glass bolt on hoods
Seems like lot of people say hood does not stay up
Some say they use factory springs
Trying to get some new opinions
olds3442 is offline
Old February 11th, 2018, 07:35 AM
ph_ckstick1
midnightleadfoot's Avatar
I have not had a glass hood on an olds, but have on Pontiac's and chevy's.
not a fan of springs on the hoods, They seem to hold them up fine, but the force on the glass when it is in the hot sun can do finny things to the hood as you push down at the other end.. nice bows in them.. I rather get a prop from a newer car and use that, even if I was to use springs.. a good breeze can be enough to help push it down and off your head if under it..
midnightleadfoot is offline
Old February 11th, 2018, 10:08 AM
72 Olds CS
RetroRanger's Avatar
I had the parts place light weight springs on a glass tek hood w no problems opening, staying open, or closing the hood. My hinges were in good shape and operated easily.
RetroRanger is offline
Old March 5th, 2018, 04:11 PM
70wcar's Avatar
I have an aftermarket all fiberglass hood on my 71 Cutlass. I have a set of the "light" springs but they don't look anything like the originals so I initially put the original springs on the hood. The hood opened pretty easily and did not take a lot of effort to close. When it is down, there is no spring pressure on the hood, it just lays there. I used the original springs all last summer and have experienced no problems.
The W25 hood is a pretty long hood and unless you have a lightweight racing version meant to be pinned on, they still have some heft to them.
You may just want to try the originals and see how they work. perhaps someone who has had an all fiberglass hood for a number of years has had issues and will chime in.
70wcar is offline
Old March 5th, 2018, 04:19 PM
stevengerard's Avatar
One of the Cutlass's I have has an all fiberglass hood with original hood hinges and springs, works fine
stevengerard is online now
Old March 5th, 2018, 05:07 PM
Old School Olds
tru-blue 442's Avatar
I have a pair on an aftermarket oai all fiber hood, they suck.
tru-blue 442 is offline
Old June 27th, 2018, 01:15 PM
Tim2017's Avatar
which brand hood do you have?
Tim2017 is offline
Old June 27th, 2018, 06:00 PM
I have a all fiberglass repop hood on my Cutlass. I bought the light springs and used them from the beginning. Never tried it with the original springs. It is OK, the hood stays up fine and opens/closes easily.
Greg Rogers is offline
Old June 27th, 2018, 06:10 PM
Tim2017's Avatar
what brand do you have? How did it fit?
Tim2017 is offline
Lee_A
February 28th, 2017 02:39 PM
oggie442
Body work
February 11th, 2013 06:48 PM
44blue
October 6th, 2011 10:05 AM
WTony
April 12th, 2010 05:36 PM
Quick Reply: Aftermarket w 25 all glass lightweight springs
