Windshield Header Replacement / Why is my car lopsided?
Old Oct 22, 2014 | 12:49 PM
rhett838's Avatar
68 Cutlass S Convertible
I have a rusty windshield header that needs to be replaced. I found an original solid piece off an old car. My problem is I just don't have the skills/tools to replace it. Anyone have any ideas on who to take it to? I called a body shop, and they recommended a windshield shop they use.
Also, my car is sitting lopsided and I have no idea why. It always has since i've owned it. I'm just now starting to try to figure out why The shocks are new, and I just had the front springs replaced. Is the frame bent? I have no idea. Any thoughts on that?
The pics below are of the bad windshield header and of the lopsided stance on my car.
Thanks for your help!
Old Oct 22, 2014 | 01:46 PM
steverw's Avatar
The parking lot stripes and the shadows make it more difficult to see the true stance of the car. The white stripe is somewhat diagonal in the pic, and the shadow is going the opposite way. try to take pics on solid colored ground with no shadows and no stripes. Measure from frame to ground in several places, compare rt. to lt. Frame could be bent, or front springs maybe be installed incorrectly. Could also be rear spring/suspension problems.
Old Oct 22, 2014 | 02:06 PM
rhett838's Avatar
That pic does make it look a bit worse than it is. It's also on a hill.
I have stuck my in hand at the top of the left tire and I get just over 2 fingers of clearance at the arc of the fender.
On the right side I get a bit over 4 fingers of clearance.
That's not an exact science, but there's something definitely off. I'll try to find/take better pics.
Old Oct 23, 2014 | 08:43 AM
First, with the tires properly inflated, park the car on a known flat, level surface and measure from the ground to the reference points on the underside of the rockers. Your Chassis Service Manual will tell you where to do the measuring. Once you have this information, you can determine if you have a real problem or not. If you do, the obvious causes are a bad spring, bent suspension, or a frame issue. It can also be a rusted or deteriorated body mount or incorrect crash repair in a prior life.
As for the windshield frame, I would be amazed if a glass shop had the skills to properly weld in the new part. I would search out a proper restoration shop and pay appropriately. This is a big deal and you'll have no end of problems if it isn't done correctly.
Old Oct 23, 2014 | 10:33 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
As for the windshield header I have a interior/soft top shop where I live that has that service(dash grafting, welding headers and other vert specific items). These guys do custom & factory interiors and tops. They do soup to nuts on verts. See if you have a similar shop in your area. I find that if you ferret out the high quality shops your better off in the long run. If the high quality shop doesnt do the type of work your seeking chances are they can recommend a place. And chances are that place will be of high quality also.
Old Oct 23, 2014 | 10:37 AM
boese1978's Avatar
As mentioned, could be the springs up front, do a visual check to insure the lower spring pig tails are in the LCA "indent".
Paladin31
Dec 1, 2013 09:00 PM
stocki26
Ninety-Eight
15
Apr 16, 2013 01:12 PM
Dan K
Dec 13, 2011 11:03 AM
The Stickman
Jun 12, 2010 10:27 PM
