window cnannels
Old Nov 22, 2009 | 03:11 PM
smknjoe1's Avatar
window cnannels
i have been workin on my 72 cutlass, an repaired the rusted window channels. My Q. is the tack or screw that holds the window clips where should i look for those or can i use screws please help
Old Nov 22, 2009 | 04:53 PM
ziff396's Avatar
If its the front window channels, then thay have small little black tapered head screws. I had to replace one of mine. I ordered aftermarket, and had to weld a small piece in at the top as they did not meet correctly. Hope this helps.
Old Nov 24, 2009 | 12:22 PM
smknjoe1's Avatar
where can i find those.
Old Nov 24, 2009 | 12:52 PM
Which window channels are you talking about? If you mean the pinchweld area around the windshield and back window, the factory uses welded-on studs to hold the trim clips. DO NOT use screws. Screws are a quick-and-dirty repair for a broken stuck and usually only lead to water leaks and rust. The correct repair is to reweld the trim studs using a stud welder.
Old Nov 25, 2009 | 05:06 AM
ziff396's Avatar
Sorry, I thought you were talking about the roof rails
wyteon
Vista Cruiser & Wagons
Nov 30, 2018 11:33 AM
f-85
Jan 16, 2012 06:10 AM
jugdish
Aug 18, 2011 09:57 AM
leepear
Apr 22, 2011 02:22 PM
James
Nov 27, 2004 07:12 PM
